Changing Piston Rings, Do I Need To Get The Bores Honed?
10 replies to this topic
#1 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 11 May 2008 - 06:08 PM
Well im going to be changing my piston rings, and i need to know if i need to get the bores honed to bed in the rings or would they be ok without honing?
#2 guesstimator
guesstimator
  • 30 posts
Posted 11 May 2008 - 07:11 PM
yep, definetly. Did the same and engine is now running sweet!
#3 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 11 May 2008 - 07:21 PM
so i need to have the bores honed? or will the pistons bed in without my bores being honed?
#4 carl68
carl68
  • 142 posts
Posted 11 May 2008 - 07:25 PM
The bores need honing, you can do it yourself as the tool isn't that expensive and it fits on an electric drill.
#5 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 11 May 2008 - 07:27 PM
any idea where i could get one of these tools?
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 11 May 2008 - 07:28 PM
At a minimum, your bores need de-glazing ( which is what you do with an electric drill and a de-glazer ) honing is done on a precision piece of equipment.
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 11 May 2008 - 07:29 PM
Halfords / Machine mart etc etc, it's like a three legged thing with abrasive scrapers on each leg.
#8 carl68
carl68
  • 142 posts
Posted 11 May 2008 - 07:32 PM
I've always called what you call de-glazing as honing as it uses honing stones which are just whetstones to rough up the bores, what you are describing sounds more like a rebore :closed:
This is the tool I am on about http://cgi.ebay.co.u...Q2em118Q2el1247
Edited by carl68, 11 May 2008 - 07:36 PM.
#9 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 11 May 2008 - 09:11 PM
Cheers ill order one of them before i fit the new pistons then :closed:
#10 maddogmcg
maddogmcg
  • 233 posts
Posted 28 June 2008 - 05:13 PM
HI
how can you tell you will get away with just honing and/or degazing rather than a rebore ?
my mg metro engine is blowing quite a lot of soot and i am stripping it down with a view to rebore / fit new rings .
if i can get away with just deglazing and re-ringing the pistons i will be happy ,does anyone know how much wear is acceptable and still get away with new rings , i can measure the bores very accurately with the correct bore comparitor /check for out of round etc .
i know if there is a ridge at the top of the bores ,it is a good indication of bore wear i am looking for actual measurements
#11 Rosslin Racing
Rosslin Racing
  • 2,408 posts
Posted 28 June 2008 - 05:38 PM
use a grape honer and read the instructions. you have measured the bores with a micrometer and checked to see if they are round? if all thats ok you can hone with the grape honer the bores lightly this allows the rings to bed in to the bores. use cheap non synth oil as well to bed in.
