Driving With No Oil Cap On
46 replies to this topic
#1 minidan
minidan
  • 2,354 posts
  • Local Club: LSMOC
Posted 11 May 2008 - 04:08 PM
do you reckon its a bad idea to drive knowing there's no oil cap on the engine?
just checking the oil level for the week ahead and when i opened the bonnet i see my oil cap is missing... no idea where its gone or if someones nicked it. but i cant get one till next weekend which is the L2B !
what could happen apart from oil being flicked all over the bonnet??
#2 A KIRK
A KIRK
  • 617 posts
  • Local Club: None now I don't own a mini
Posted 11 May 2008 - 04:12 PM
Well you loose oil, blow enigne up, or create a fire etc.
There are things called phones where you could ring up and order one, then have it delivered to you
#3 minidan
minidan
  • 2,354 posts
  • Local Club: LSMOC
Posted 11 May 2008 - 04:16 PM
yes thats very helpful thankyou...
but that doesnt really help me when i need to use the car in about 12 hours time. even if i phone minispares i wont get it till wednesday
#4 Sam Walters
Sam Walters
  • 2,765 posts
Posted 11 May 2008 - 04:20 PM
i gues a temory fix would be to get a flat peice of fairly thick flat plastic. and whop that over the top and try to hold it on with something.
#5 minidan
minidan
  • 2,354 posts
  • Local Club: LSMOC
Posted 11 May 2008 - 04:21 PM
im going to have to make some kind of temporary fix.
#6 minidan
minidan
  • 2,354 posts
  • Local Club: LSMOC
Posted 11 May 2008 - 04:22 PM
if i cut out some thick plastic from a sack i have and cable tie it on do i need to poke a small hole in it for breathing?
#7 RobJaxon
RobJaxon
  • 225 posts
  • Local Club: dont know
Posted 11 May 2008 - 04:23 PM
yes, oil will probably end up everywhere .
#8 nathansminis
nathansminis
  • 584 posts
couldnt you stick a bit of cling film over the hole and put an elastic band around it for now?
or do the plastic caps breathe???
just a thought
#9 minidan
minidan
  • 2,354 posts
  • Local Club: LSMOC
Posted 11 May 2008 - 04:25 PM
just a thought
this is the kind of thing i was thinking of. but with a thicker piece of plastic and a cable tie
#10 sweetser
sweetser
  • 3,995 posts
Posted 11 May 2008 - 04:30 PM
cant you use abit of duck tape
#11 minidan
minidan
  • 2,354 posts
  • Local Club: LSMOC
Posted 11 May 2008 - 04:33 PM
could do but i dont have any and the heat from the engine might make the glue melt and fall off.
anyway, ive made my rocker cover into a bit of a jam jar type thing. i'll put a picture up in a bit
#12 wakkoboi
wakkoboi
  • 414 posts
Posted 11 May 2008 - 04:37 PM
haha sounds brilliant cant wait t c pics
#13 *DJH*
*DJH*
  • 4,972 posts
Posted 11 May 2008 - 04:48 PM
all you need to do is get a lid from a nescafe jar of coffee, drill a 2mm hole in the top, then tape it down with duct tape (not covering the hole obviously)
sorted :closed:
#14 sidq
sidq
  • 238 posts
  • Local Club: www.smocmalaysia.com
Posted 11 May 2008 - 05:06 PM
huhu...i like that idea.i want to try it.thanks.
#15 A KIRK
A KIRK
  • 617 posts
Posted 11 May 2008 - 05:11 PM
or a temp fuel filler cap from the local petrol station.
