System 4 Fuel Catalyst
Scott.Tamson
, May 04 2008 12:21 AM
7 replies to this topic
Posted 04 May 2008 - 12:21 AM
Has anybody used this product that allows you to run the car on unleaded fuel ?
Thanks.
Thanks.
Posted 04 May 2008 - 12:26 AM
Have you tried snake oil?
Posted 04 May 2008 - 12:55 AM
Havnt tried anything
Mini's not on the road...yet.
What you guys reckon is the stuff to be using ?
Posted 04 May 2008 - 07:59 AM
It is not possible to 'catalyse' unleaded into leaded, you have to add some lead or substitute to it. All these products are a con, you can't put a bit of lead in the tank or the fuel lines and hope it will slowly disolve. Nothing will happen. Pure lead would be a terrible thing to add anyhow, fuel additive should be tetra-ethyl lead. The best additive to use based on much research and the opinions of many on the forum is Castrol Valve Master Plus. This provides a lead replacement that actually does what it is supposed to do and lubricates the valve seats while also boosting the octane of regular unleaded from 95 to 97 making it a direct replacement for 4 star. If you add it to super unleaded of 97 RON you will get a lead replacement fuel with 99 RON, nearly 5 star standard. All you do is add a drop of it to your tank when you fuel up. I seem to remember that you add it in at a concentration of 1:1000 so a bottle lasts for ages.
Posted 04 May 2008 - 08:39 AM
I don't believe a word of it and never have. They provide no decent testing to back up thier claims and generally don't wish to partake in things such as proper testing.
Link: It's a bit long but quite interesting
For my landrover I use Castrol Valvemaster additive: I did a lot of research at the time and this was, by a considerable margin, the best product for [assisting with] the prevention of valve seat recession and was proven to work.
Edited by sixwheeler, 04 May 2008 - 08:39 AM.
Posted 04 May 2008 - 09:44 AM
Yeah i bought a box of 60 'Castrol valvemaster' syringes. You just pop one in with every tank of fuel and off you go.
Posted 29 April 2011 - 11:33 AM
For accurate calibrated dosing of the fuel using Castrol Valvemaster or others with a 1:1000 dose rate there is a new flow sensitive valve available that fits in-line and holds enough additive for several tanks of fuel. Available through Zportec's website.
Posted 02 May 2011 - 09:54 PM
cant you just get an unleaded head?
