Spi To Carb
12 replies to this topic
#1 minitom1
minitom1
  • 74 posts
  • Local Club: minis and oatcakes
Posted 26 April 2008 - 10:43 PM
i want to change my spi cooper to a carb. how hard is it to do and what is involved???
i no the ecu has to be changed but how??
any addvice will be appreicated
#2 Ethel
  • 25,913 posts
Posted 26 April 2008 - 10:46 PM
How hard it will be to get the car through the emissions test afterwards would be a bigger worry.
#3 minitom1
minitom1
  • 74 posts
Posted 26 April 2008 - 11:04 PM
so there is more problems than just changing then lol.
#4 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 27 April 2008 - 05:20 AM
why do you want to change to a carb?
#5 Git
Git
  • 1,269 posts
  • Local Club: Humanity
Posted 27 April 2008 - 05:54 AM
I thought about changing Git over to carb, I was quoted 'about £500' the garage did not want to do it.
Other than the wiring, you'll have to change the fuel tank and there's the expense of the new carbs.
Didn't bother in the end, Gits engine was built around the injection system and runs great.... why *male chicken* it up?
#6 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 27 April 2008 - 08:08 AM
right then, well I'm not an expert on fuel systems by any means but what i do know is that i get irritated when things get blown up into some great big myth when they are really quite simple things to do or someone knows very little of what their talking about, changing a rear sub-frame comes to mind (and dont even get me started on "RSP alloys" or the "mini Mayfair HLE limited edition" :unsure: )
so i have found the mini magazine article on the injection to carb conversion.
like i said, I'm no expert, but the comment "i was surprised how easy it was to do and how few extra parts you need to make the change over" is in the introduction :ermm:
Edited by THE ANORAK, 27 April 2008 - 08:11 AM.
#7 Jammy
Jammy
  • 25,397 posts
Posted 27 April 2008 - 08:14 AM
They didn't state how they got on with the emission's test during the MOT though...
However, if you can prove the age of your engine, the emissions test should be based on that, not the age of the car.
#8 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 27 April 2008 - 08:22 AM
well think there must be another guide somewhere as this one doesn't mention much about the ECU. I'm sure i read that its kept in place to control the ignition.
yes there is much more to say on this subject but i was getting tired of the same old answers to the problem. hopefully this will move things on a step ???
#9 minitom1
minitom1
  • 74 posts
Posted 27 April 2008 - 01:11 PM
thats a massive help thank you will have to go through it.
big thanks to the anorak :unsure:
#10 miniboo
miniboo
  • 9,327 posts
Posted 27 April 2008 - 03:34 PM
you still havent said why you want to change to a carb. are you having problems with the injection? or do you think you will get more power with a carb(i doubt it)?
#11 Ethel
  • 25,913 posts
Posted 27 April 2008 - 03:59 PM
Wow, you can manage to do the whole conversion using just an orange pencil :unsure:
#12 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 27 April 2008 - 04:02 PM
Wow, you can manage to do the whole conversion using just an orange pencil ^_^
:unsure: :ermm: :cry: ^_^ ^_^
#13 Aus
Aus
  • 132 posts
  • Local Club: MiniClubJersey
Posted 27 April 2008 - 05:02 PM
I put a Swiftune 1380 in my SPi Cooper a few years ago. Basically I replaced the tank with a carb tank and a facet pump. Since the engine came with a dizzy I just wired in a ignition live to the coil. I left the ECU in place and since the car still used the SPi gearbox & lighten fly I kept the crank sensor in place (not sure if it makes any difference if you are running a mechanical dizzy). The only actual wiring mod I made was to cut the wire going to the temp guage and extend it round to the head to pick up from the sensor.
It was a very simple job.
