Definitive Ice Guide
50 replies to this topic
#31 tcw_lk
tcw_lk
  • 33 posts
  • Local Club: Mighty Mini Club of Sri Lanka
Posted 07 August 2008 - 05:41 PM
Do tweeters make a difference? if so also where is the best place to put them
Best place for tweeters are some where in the front. So they'll give the impression that the sound is coming from the front, as the location of a bass source is not easy to identify as a treble sound source(tweeter)
hope this might help
Edited by tcw_lk, 22 August 2008 - 04:58 PM.
#32 jwb_moto
jwb_moto
  • 1,387 posts
  • Local Club: PMOC
Posted 20 August 2008 - 05:54 PM
Anybody got any tips on sound staging and imaging?
im guessing its not a case of point the speaker at you and of you go???.....
should all the speakers point to the centre of the environment?
#33 norwegianminiman
norwegianminiman
  • 323 posts
  • Local Club: norwegian mini cooper club
Posted 20 August 2008 - 07:20 PM
as far as i have gathered, one of the things you need to do is to position the speakers in such a way as to minimize the difference in distance between the speakers and the listening position (usually driving seat)
pretty sure this has been answered a few times...
#34 Ouster
Ouster
  • 2,986 posts
  • Local Club: Looking
Posted 21 August 2008 - 09:53 AM
I'm angling my pods up, and then they're being bolted to the dash rail so I can fiddle with the angle they point into the car for the best sound.
#35 monster_mini
monster_mini
  • 981 posts
Posted 21 August 2008 - 12:13 PM
hi i would really like a small sub so i have some nice (not rediculous) base.
but i also really would like to keep my boot empty ish so i can still access everything.
would a 10 inch free air sub fit on the partial shelf and would it sound ok.
do free air subs sound ok
who does the best speakers? in peoples oppinion
#36 norwegianminiman
norwegianminiman
  • 323 posts
Posted 21 August 2008 - 12:24 PM
Another question asked a lot...
Free air subs aren't generally recomended, they dont sound as good as one in an enclosure. If you want bass without using boot space, you might want to consider an 8" or two under the rear seats...
#37 Ouster
Ouster
  • 2,986 posts
Posted 21 August 2008 - 04:44 PM
The best (and easiest) space-saving option sub wise is to have two Elemental Designs 7kv.2 6" subs boxed under the rear seats, or two Genesis Profile 69s in the parcel shelf.
The latter is the option I'm going for in my install.
#38 tom275
tom275
  • 31 posts
Posted 17 December 2008 - 03:35 PM
Ive currently got a 12"sub, 6x9, and component front speakers, the 6x9 are really only to create good all around sound and for people iun the back but there not that important, i currently run all speakers, except obviously my sub of the head unit, Alpine 4x45watt, how much difference in quality do you think i will find if the are amped, its really only for quality not for sound.
Great guide by the way.
thanks
#39 BishopMaverick
BishopMaverick
  • 163 posts
Posted 28 January 2009 - 07:18 PM
I tried a free air sub and it was useless, I cashed it in and got an alpine compact sub (avalible from CAD. Linky: http://www.caraudiod...ao3pkk881fj19d1 ) and bolted it to the boot wall opppsite the fuel tank if you were really worried about space you could bolt it to the parcelshelf but then it's facing the wrong way so not sure what the effect would be. However it is still not as good as a full size enclosed sub so it is only ever a compromise, but what isn't :cry: ???
Only what I've done, I would recommend sampleing a compact first just to make sure it's the sound your after.
Good Luck :lol: ,
B.
#40 Radleigh
Radleigh
  • 126 posts
Posted 05 February 2009 - 01:16 AM
Good thread, just what I need. >_<
#41 Junior Mini
Junior Mini
  • 313 posts
Posted 20 February 2009 - 12:37 AM
Any tips on Split charging systems???
#42 joewb
joewb
  • 436 posts
Posted 10 July 2009 - 11:46 AM
simple question i know but wanted to check first, are all ISO leads standard? meaning it doesn't matter what i get as long as its an ISO lead?
(example)
Joewb
#43 jimmyH
jimmyH
  • 260 posts
Posted 04 August 2009 - 04:56 PM
I have a set of Vibe components, all correctly wired up to their cross overs.. However they do not seem to be doing their job to its full extent. The low range speakers in the back are playing some treble and vice versa for the tweeters attempting bass. Consequently the tweeters are distorting much earlier than they should.
On my cross overs i have a switch for 3 or 6 db, or something like that without checking i cannot be sure. Can any one enlighten me as to why my cross overs are not doing everything they should.
#44 Brams96
Brams96
  • 2,308 posts
Posted 18 October 2009 - 08:29 PM
It sounds like the crossover points are wrong for the speakers, are the crossovers for those speakers? Do you have a model number on the components? Some crossovers have an attenuation set up so you can reduce the high end frequencies a bit. Do you know the drop off rate for the crossover points? (-12db, -18db etc)
#45 monster_mini
monster_mini
  • 981 posts
Posted 11 January 2010 - 05:41 PM
ello:P:)
i have approx £200-£300 to spend on an install, thats head unit, speakers, cables the lot:P i currently have no system atall in my car, but would like a good one:)
i can increase budget if needed too but thats how much i was looking to spend:P
i have an ipod touch and would prefer to be able to use that:)
what do you think of the head unit? http://www.caraudioc...01r_p-23613.htm
all ideas are welcome, i have been given some pioneer approx 50 watt rms speakers but unsure on quality, could be used if nessesary:)
thanks
nick
5 user(s) are reading this topic
0 members, 5 guests, 0 anonymous users
