hi basically i need to run a elec fuel pump for my new 1380 engine , just wondering how easy are they to fit , as far as i know they mount in the boot next to the fuel tank thats it , any idvice please?
![Photo](https://secure.gravatar.com/avatar/faf6b753a7ffc614ae5bf491af5990ee?s=100&d=https%3A%2F%2Fwww.theminiforum.co.uk%2Fforums%2Fpublic%2Fstyle_images%2Ftmf%2Fprofile%2Fdefault_large.png)
Facet Fuel Pump Fitting?
1380davis
, Apr 23 2008 08:22 PM
3 replies to this topic
Posted 23 April 2008 - 08:22 PM
Posted 23 April 2008 - 08:35 PM
anyone?
Posted 23 April 2008 - 08:43 PM
A quick search should get you a wiring diagram to safely install the pump
My install was as follows
tank to pump(with built in filter) to front to rear fuel pipe under the car to a filter/pressure regulator mounted on the bulkhead to the carb
All depends on the pump you use
Posted 23 April 2008 - 09:06 PM
I fitted mine to the N/S web of the rear subframe - it's one of the small square solid state ones so being under the car isn't a problem and it's quieter than if you mount it in the boot (where my Dad's one is). Here's a pic:
![Posted Image](http://i240.photobucket.com/albums/ff247/jayare72/FuelPump.jpg)
Hope that helps,
JR
Hope that helps,
JR
