Engine Running On ?
Posted 18 April 2008 - 07:35 AM
i just dont no why it does it and can i stop it?
does a 1989 mini have a anti-run-on valve?
Posted 18 April 2008 - 11:12 AM
Fitting an anti run on valve will cure the problem though.
Sometimes carbon build up can cause run on, so this might be worth investigating first.
Posted 18 April 2008 - 11:26 AM
You can stop it via the clutch. Put the car in gear. Turn off the engine and slowly raise the clutch to stop the engine.
Posted 18 April 2008 - 12:14 PM
Same thing happens when people fit exchange flowed heads. Occasionally you get onetaht has been "made" on an old casting that was put in as an exchange head that has worn plug threads and causes run on - people have just put it down to having a "tuned" engine.
As said above, check the timing and mixture to illiminate these as possible causes. Might be worth whippng the head off and giving it a de-coke to as extreme build up of carbon deposits can cause run-on too
Posted 18 April 2008 - 03:09 PM
Fuel mixtures are set to lean these days in an effort to cut emmissions but older engines don't like it and tend to run hot hence pre ignition (run on ) after switching off.
Ignition timing should be advanced as far as poss to the point of pinking then backed off a bit on an old engine.
The settings in the manual should be disregarded to a point and the engine given what it needs rather than what it should have by the book.
Wear in the distributer and timing chain wear both contribute to retarded timing which then leads to pre ignition (run on).
In summary I would suggest running the mixture slightly rich rather than lean and timing advanced as far as poss without pinking.
Posted 18 April 2008 - 04:02 PM
Posted 18 April 2008 - 05:48 PM
Posted 18 April 2008 - 08:52 PM
You can stop it running on by pressing the accelerator pedal as you turn the key off. I know it sounds backward, but it works! I have one of these HC engines and I do this all the time. Don't worry, it doesn't flood it either!
That's a good idea, the extra unburned fuel will cool the valves and combustion chamber.
I always pull the choke at the same time as I turn off at night if the weather is cold, just enough to put extra fuel in inlet, then it fires first time in the morning.
Posted 18 April 2008 - 08:57 PM
Paul.
Posted 18 April 2008 - 09:50 PM
Posted 18 April 2008 - 11:31 PM
Posted 19 April 2008 - 02:14 AM
it just works. My car is fuelled and timed correctly and still occasionally runs on, so I just do this, and have done it for years now, it's turned to habit!
Posted 07 August 2008 - 08:16 AM
I came across this document while trying to fix it:
http://www.mgtoronto...tion-run-on.pdf
Wonder if the same trick would apply to a Mini... I'm gonna have a go at it, see if it does anything for me, if not I'll just rip it out and think about advancing the timing again or enriching the mixture slightly.
EDIT: Never mind, I found out this fix is for a different issue... I guess my problem is I retarded the timing too much and will have to readvance it to a slight pinking... sigh.
Edited by andersemil, 07 August 2008 - 08:53 AM.
Posted 07 August 2008 - 09:08 AM
Yes I'm sure this is one of the main problems
This is what I do with mine, I kind of stalls it.
Posted 07 August 2008 - 09:18 AM
This is a very bad idea as you are pouring fuel into your cylinders and washing the oil off of them. Consequently when you next go to start the engine you get increased bore wear due to inadequate lubrication of the cylinders. Bore wash is a major contributor to premature engine wear!
Sorting the problem is down to correct engine and ignition set up. I.e. do a decoke and then set up the points with a dwell meter and only then look at timing. This is assuming that you have already adjusted tappet clearance etc. and that your engine is not fubar'd and isn't drinking oil and carbonising up all the time
