Mounting Bullet Mirrors
Posted 17 April 2008 - 07:36 AM
and i was just wondering how i can mount them as i cant get to the other side of the door to screw the bolts in.
Any help will be appreciated.
thanks
Posted 17 April 2008 - 07:49 AM
but if you want to fit them as they are then its a case of dropping the window to the bottom and removing the inside and outside chrome weather strips (should just carefully pull off) this will give you just enough access to get your fingers/spanner into
keith
Posted 17 April 2008 - 07:54 AM
also if i get this adapter will i still need to drop the window to access to the bolts, i dont think i can do this as the front 1/4 window is in the way
Posted 17 April 2008 - 07:55 AM
Also I think those may technically be wing mirrors..which isn't a problem because its what I have fitted to my doors and my bro-in-law
Wing mirror http://www.minispare....aspx?pid=35385
door mirror http://www.minispare....aspx?pid=34464
Posted 17 April 2008 - 08:05 AM
Posted 17 April 2008 - 08:08 AM
Posted 17 April 2008 - 08:48 AM
http://www.minispare...p;sub_cat_id=38
Posted 17 April 2008 - 08:57 AM
thanks
Posted 17 April 2008 - 03:03 PM
. I had a one years ago where there was 2 screws that went through the outside but I believe some are clipped together either way it will be fairly straight forward
Posted 17 April 2008 - 03:37 PM
thanks for the help/
Posted 18 April 2008 - 08:41 AM
Posted 14 May 2008 - 03:56 PM
You have bought wing mirrors. They're not meant to go on your door.The visibility will be absolutely terrible. (I've been there and done it myself)
There is a way of getting them on, you have to wind the window right down,.. have a tiny spanner on the inside with the not stuck to it (i found blue tack worked well) and if you're lucky and can thread the nut onto the bolt with the first turn of the spanner then you can get them on.
It's very difficult to attach these mirrors to doors and if you do,.. You wont see anything through them anyway. You'll find if you were to fit them to the wing they would be Very straightforward, that is afterall where they have been designed to fit.
You need these instead,... door mirrors.
CLICKY <-- see how they have a plinth that allows fitment to your door?
Here are some nicer looking ones with different plinths that will still fit your door:
CLICKY
Posted 14 May 2008 - 04:29 PM
Edited by lrostoke, 14 May 2008 - 04:30 PM.
