Replacing A Panels
nightroamer
, Apr 09 2008 07:11 AM
7 replies to this topic
Posted 09 April 2008 - 07:11 AM
Hi there guys,
About to buy a mini which i know needs 2 new A panels.
Has anyone does a guide on this? I have plenty of experiance welding up minis and panels but never done an A panel oddly enough.
Tom
Tom
Posted 09 April 2008 - 11:03 AM
Hi there guys,
Tom
Here you go...
http://www.theminifo...showtopic=40659
Posted 09 April 2008 - 11:10 AM
Yea just read this, does anyone have any pictures of the process?
Also im looking for a nice exploded diagram of the mini body/panels, maybe from a workshop manual?
Thanks guys
Thanks guys
Posted 09 April 2008 - 11:32 AM
It's really stupidly easy. If you've done work on minis before, you'll figure it out no problem. Stick your head under and have a look! slightly more complicated on mk1's though I believe.
Posted 09 April 2008 - 11:43 AM
Cool, thanks for the input guys. My project mini has been laid up for a while now, just not had the time.
I'm gonna try doing these panels as soon as i have picked up the mini, just worried about the fit, although i have ordered haritage panels.
Posted 09 April 2008 - 11:59 AM
I actually have only ever fitted non genuine A panels, and the fit has always been great, so I guess heritage will be even easier.
Posted 09 April 2008 - 12:01 PM
Somerfords website gives a fair few exploded body pictures
http://www.somerford...ody-panels.html
And like mentioned A panels are pretty simple to replace..
I've done a few, easiest way to remove is to run a cutting disk up the seam between wing and A panel, then grind off the welds on the door pillar section..
clean up the wing ready to reweld new A panel., check condition of flitch panel where it meets the doorpost section, on the two I've done the've all gone there as well.
Not sure about heritage panels, but on the pattern A panels you have to bend the lip of the section that hooks onto the door pillar.
I just find a piece of sheet same thickness as the lip on the door pillar and bend over the edge.
It'll make more sense when you remove the old panel and see your replacement panel.
Posted 09 April 2008 - 01:41 PM
Cool thanks for the links, there pretty usefull.
I think ill prob use non-gen on the project car but not on this one.
Cheers guys
Cheers guys
