Mk1 fiesta caliper conversion
562 replies to this topic
#121 $way
$way
  • 720 posts
  • Local Club: ...
Posted 02 February 2007 - 10:34 PM
ive read your post over on minifinity but ill reply here...
ive measured mine to be 48mm...
#122 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 02 February 2007 - 10:45 PM
Cheers mate... I might get some of the Mk3 and mock them up as I can get them local. P.S this seems like a great site.
#123 $way
$way
  • 720 posts
  • Local Club: ...
Posted 03 February 2007 - 12:11 AM
coolcool,
will be interesting to see if mk3's fit, as they are probably better calipers than mk1 and 2's.
could you post in here your results?
cheers
J
#124 Gr4h4m
Gr4h4m
  • 1,802 posts
Posted 03 February 2007 - 11:19 AM
coolcool,
cheers
J
Bad news mate I have found the discs on the Mk3 were 240mm where the Mk2 are 221mm so I guess the caliper is spaced out more... so more looking for Mk2's.....
#125 $way
$way
  • 720 posts
  • Local Club: ...
Posted 03 February 2007 - 11:35 AM
bummer...
have you contacted the fiesta breakers in the link i posted previously, im sure they could help you out
where abouts are you there's got to be some scrap yards around your way??
J
#126 bert998
bert998
  • 2,558 posts
Posted 03 February 2007 - 11:57 AM
Yeah fiesta breakers are good, his place is down the road from me and he has mk1 and 2 calipers piled up. Not particularly cheap at £20 each but he's the one with the stock. Good luck, mine are still in the cupboard :withstupid:
#127 Gr4h4m
Gr4h4m
  • 1,802 posts
Posted 04 February 2007 - 01:06 AM
Yeah fiesta breakers are good, his place is down the road from me and he has mk1 and 2 calipers piled up. Not particularly cheap at £20 each but he's the one with the stock. Good luck, mine are still in the cupboard ;)
thanks Guys I did contact him and he had some but he wouldn't post them, and its a bit of a drive from Chester.... Still I drove to Stockport today as a breakers said they had two I got there and they had one.... but then the day got better I was visiting my mother-in-law in Lancaster where I used to live so I checked the local breakers and he had just had a Mk2 dropped off, do I got two calipers for £20..... so I'm in business.... yipeeee. I currently have a spare I think it drivers side...
#128 $way
$way
  • 720 posts
  • Local Club: ...
Posted 04 February 2007 - 02:05 PM
good stuff.
told you sfrappies are the place to go.
have you got everything else?
i just need to turn my discs dfwn and get some hoses made up.
#129 Gr4h4m
Gr4h4m
  • 1,802 posts
Posted 04 February 2007 - 09:49 PM
good stuff.
Sort of... getting the rest of the bits form Minispares etc as we are rebuilding the hubs with bearings and ball joints etc...
I don't think the Mk3 will go anywhere near 10inch wheels..... we had a look at Xr2 which use the same size disc 240mm and it wouldn't go
#130 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 04 February 2007 - 10:21 PM
Getting my 8.4" setup on wednesday.
Just need disc driveshafts, metro turbo drive flanges, fiesta calipers.
I've got some adpaters for the brake lines made up, but i'm looking at this banjo bolt idea too.
#131 Gr4h4m
Gr4h4m
  • 1,802 posts
Posted 04 February 2007 - 11:22 PM
The drive shafts should be the same the CV joints are different. I'm using the same drive shafts as I have the rubber inner connection not the later pot joints...
#132 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 04 February 2007 - 11:26 PM
hmmmm well i'm going form drum to disk.... so what's the crack? can i use drum shafts???
#133 markrally
markrally
    Z Cars
  • 1,378 posts
  • Local Club: Miniaddicts.co.uk
Posted 04 February 2007 - 11:58 PM
just been comparing pad area of the mk1 & 2 calipers and the mk 2 are a lot bigger so they are the ones to go for and a lot easier to find than the mk1's aswell.
#134 bert998
bert998
  • 2,558 posts
Posted 05 February 2007 - 12:03 AM
how are your adaptors made retro?
#135 Gr4h4m
Gr4h4m
  • 1,802 posts
Posted 05 February 2007 - 10:18 AM
My cars on Drums... The theory is that the drums shafts should fit the new outer Disc type CV joint... Will be able to tell you when Mark and I put it all together...
Do you have the inner rubber cross joints that are held with U-bolts???? These rubber connections is why I'm using the exisitng drive shafts as the later type use POT joints which will mean taking the end off of the Diff....
