Mk1 fiesta caliper conversion
#106
Posted 08 January 2007 - 08:32 PM
i never completed it but steverowe on here bought the whole lot off me so should be putting them on his.
#107
Posted 08 January 2007 - 08:44 PM
#108
Posted 02 February 2007 - 12:07 PM
Pickup76 is using 5x10 supaslots, I'm going to be using 6x10 supaslots.... any forseable with my 'extra inch?'
Picking up my hubs and disks and calipers next wednesday wooooooooot!
#109
Posted 02 February 2007 - 12:57 PM
#110
Posted 02 February 2007 - 12:58 PM
Edited by Pickup76, 02 February 2007 - 01:00 PM.
#111
Posted 02 February 2007 - 01:07 PM
I was hoping to run Minispecial arches... they fit the back of the car perfectly with spacer drums on, just covering the tread. I'll have to see how much the fronts stick out.
I'm converting from drums to disks... so i take it'll need Disk type drive shafts too?
#112
Posted 02 February 2007 - 01:27 PM
#113
Posted 02 February 2007 - 01:52 PM
#114
Posted 02 February 2007 - 03:13 PM
i have 10*6 wellers ready to go on mine how far outside the wing will they sit with the festa brake set up then?
#115
Posted 02 February 2007 - 03:21 PM
#116
Posted 02 February 2007 - 05:52 PM
cheers
J
#117
Posted 02 February 2007 - 08:20 PM
#118
Posted 02 February 2007 - 08:46 PM
i got my mk2 calipers from a scrappy...
im sure someone posted to a link not sure if it was in this thread, might even have been on minifinity, but it a place where you could buy calipers i think they were new old stock but im not sure if they included the mouting bracket...
i reckon you should have a ganders round some scrapyards....
J
#119
Posted 02 February 2007 - 09:05 PM
someone mentions in there mk3 calipers wont work because the master cylinder on a mini is too small...
heres the thread here
you might be able to find some mk2's here Fiesta Breakers
J
#120
Posted 02 February 2007 - 09:20 PM
just re-read the thread where i first came across the conversion,
J
Thanks Mate going to give it a full read... Its strange because I got some data on the Mk3 non ABS solid disc caliper and it has the same size bore piston 48mm as the Mk2.
I know the XR2 is too big because I have some XR2 calipers and they take the vented disc which id 19.9mm wide and the solid disc is 10mm wide + the XR2 piston bore is 54mm wide... the Std solid disc Mk2 piston is 48mm...
