I dont think so without using a spacer. The callipers will catch the inner rim where the centre is welded to the outer rim.
Mk1 fiesta caliper conversion
Pickup76
, May 05 2005 05:43 PM
562 replies to this topic
#556
Posted 14 December 2009 - 09:51 PM
#557
Posted 15 December 2009 - 12:28 AM
hmm if someone could check that would be extremely appreciated! i have a mini that HAS to go on s wheels, just because its all part of what the car will look like when its finished, sort of a euro modern day racer, because im buying a bare shell only it will never get back to original.
if the calipers need a bit of mods i dont mind this, nor do i mind a "sensibly" sized spacer.
please let me know, theres a few people i have spoken to who would like an answer to this
thanks
scott
thanks
scott
#558
Posted 15 December 2009 - 07:35 PM
I have done this conversion using Mk2 Fiesta calipers. The standard 10" wheels fouled on the caliper, and the only cure is to grind some material from the caliper and fit a 5mm spacer to the hub.
Another problem with the whole setup is that to be legal you will probably have to run arches, as a combination of the Metro hub and 5mm spacer move the wheel from under the wing.
In an attempt to find wheels which will fit and may have an offset which will bring them back under the wing I made a cardboard template of the hub and caliper profile which I could take to shows and try inside various wheels. I could find only 2 possible candidates which would fit without the 5mm spacer and clear the caliper and with an offset which may bring them back under the wing. These were 10x4 1/2 Rostyles and the aluminium cooper s pattern 4 1/2 x10, I also found the steel cooper s 4 1/2" 9 hole type ( not reverse) will not fit without the use of spacers, although I don't know how thick they would need to be.
If you don't mind running arches then almost any wheel will fit, some with spacers and some without.
#559
Posted 15 December 2009 - 11:48 PM
thats brilliant, thankyou thats exactly what i needed to know! arches are not a problem, neither is a sensible spacer, i just didnt want to have to space my wheels out by an inch and cut half the caliper off!
i will get working on this now, i havnt picked up the shell yet, trying to get a few bolt on bits ready first before i clear space for the shell.
thankyou very much!
scott
thankyou very much!
scott
#560
Posted 27 October 2010 - 08:08 PM
Hi there,
I've been lately starting to look for the usual fiesta calipers in order to tackle the famous conversion...
I've just got one problem : I sourced some fiesta calipers but the seals in them are shot and I can't seem to find them anywhere on the interweb...
Oh and another thing : would anyone be able to tell me what type are my calipers judging by the piston size?
It's 50,9mm high and 47,9mm in diameter.
MK1, MK2??....
Hope this is the right place to ask.
Thanks,
Marc
MK1, MK2??....
Thanks,
Marc
#561
Posted 27 October 2010 - 08:14 PM
Mk1 callipers have metal sliders to hold the callipers in, mk2 have bolts/pin type things that the calliper side on.
Or just cross my palms with some sliver and save your self the trouble and have a look in the classified section.
#562
Posted 11 November 2010 - 02:36 PM
Threads abit old now but if anyone is looking for metro drive flanges you can purchase them from rover still for a suprising £26+vat
#563
Posted 26 January 2011 - 07:56 PM
Anyone has tryed those wheels with fiesta calipers, or only 6inch do the job?
http://www.minispare...mp;prod_id=1317
