Mk1 fiesta caliper conversion
#511
Posted 04 January 2009 - 08:15 PM
it appears that
Mk3 fiestas without abs
Mk4 fiestas that are 1.25i manual, 1.3i and 1.8D use a 48mm dia piston for 10mm thick disks which is the same as the mk1's and standard non xr2 mk2's so i wonder if these caliper would fit onto mk2 carriers?
I know they use larger dia discs normally but doesnt the carrier determine the size of the disc (distance from the centre of hub) if that makes sense.
If these would fit this would make sourcing clipers even easier.
#512
Posted 04 January 2009 - 08:21 PM
#513
Posted 15 March 2009 - 10:11 PM
Bled just the fronts and took it for a spin, they are feeling bit spongy compared to the 8.4" set up i took off though.
Would it be worth bleeding the rears as well ?
Looking good thoough and the MWS 6" x 10" wheels are looking good ! I'll post some picks when i get a chance.
#514
Posted 15 March 2009 - 10:30 PM
Chris
#515
Posted 15 March 2009 - 10:48 PM
I'll bleed the whole lot tomorrowow night and see how i get on.
#516
Posted 24 April 2009 - 02:43 PM
Looking for the bits to do this conversion myself.
#517
Posted 24 April 2009 - 03:43 PM
Ive just found a website that gives all the spec of fiesta callipers
it appears that
Mk4 fiestas that are 1.25i manual, 1.3i and 1.8D use a 48mm dia piston for 10mm thick disks which is the same as the mk1's and standard non xr2 mk2's so i wonder if these calliper would fit onto mk2 carriers?
I know they use larger dia discs normally but doesn't the carrier determine the size of the disc (distance from the centre of hub) if that makes sense.
If these would fit this would make sourcing callipers even easier.
what web site was it that had the specs could you put up a link please if poss
michael
#518
Posted 24 April 2009 - 04:02 PM
was a long while ago mind so just have a look through a few sites
#519
Posted 24 April 2009 - 04:04 PM
michael
#520
Posted 02 May 2009 - 09:30 AM
#521
Posted 02 May 2009 - 05:15 PM
you sohlud see that the webbing on the bracket fouls the hub so you have to releave a bit of the web to clear the hub
If you look on youtube there is a guide which shows which bit i mean aswell
#522
Posted 03 May 2009 - 05:16 AM
Just found these pics of the flanges, there not pics i took, but pics i found on the web showing the difference.
#524
Posted 06 May 2009 - 09:01 PM
#525
Posted 08 May 2009 - 11:37 AM
Is
Bulkhead fitting HETBF1-3 x2
Bulkhead nut BNS5/8W x2
Hose end E321-3 x2
Converter from imperial to mm MMS5-3-31 x2
copper washers WC-3/8 x6
Airoquip hose TFE3 32 32cm
A well known format? Theres a place near me that makes custom hoses, will they understand that?
Anyone else got any places to try and what did you ask for? cheers!
Moquip got a website?
Jordie
