Mk1 fiesta caliper conversion
#481
Posted 20 September 2008 - 07:09 AM
freaker
#482
Posted 22 September 2008 - 09:27 PM
#483
Posted 22 September 2008 - 09:38 PM
how about 6 x 10 mini lights ?
What brand of mini lights? but i would imagine they will considering iv managed to get steelies to fit and they along with mambas are the most difficalt to get over other breaks, they usually only fit over the standard 7.5" calipers.
#484
Posted 01 October 2008 - 08:00 PM
#485
Posted 06 October 2008 - 06:46 PM
#486
Posted 06 October 2008 - 08:44 PM
#487
Posted 10 October 2008 - 01:23 PM
#488
Posted 10 October 2008 - 02:28 PM
#489
Posted 10 October 2008 - 07:15 PM
#490
Posted 13 October 2008 - 09:46 PM
Can anybody tell me what part of the original hose/bulkhead fitting i need to be removing.........
I've tried undoing the hose side of the subframe with no joy. Should i be undoing the rigid brake pipe first then undoing the bulkhead fitting the radiator side of the hose. Is the large nut on the inside of the subframe the other side of the bulkhead fitting. What about the drivers side?
Cheers,
#491
Posted 14 October 2008 - 09:29 PM
All fits a treat though, this is a great conversion. Hope the braking is good too.
#492
Posted 19 October 2008 - 10:55 PM
any news on the positioning of the driveshaftWell iv had this all up and running for about 250 miles now and they have seemed to work prety well, but i have just found out teh major downfull to this conversion, having a look over my engine today i saw that the driveshaft (pot joint part) was about 10-20mm out of the diff!!!
So i got all scared thinking my hub nut had come lost or ball joint was about to go, so i took the wheel off and inspected everything, so i couldnt think what was going on, but i had a good think about it and remembered the metro flanges pull the wheels out 10mm either side, so this will be bringing the driveshaft out that extra distance...
So now i really dont know what to do.
So if anyone else has dont this conversion i would check your driveshafts.
If anyone has come accross this how have you overcome the problem? the driveshafts is still gripping properly, but there cant be much of the spines in contact...![]()
EDIT: Having a think about it this might not be right as the gap between the hubs and gearbox will still be the same...i dont know what to do has enyone else experienced this?
i want to do this conversion and just trying to get the pros and cons.
#493
Posted 20 October 2008 - 12:43 AM
#494
Posted 20 October 2008 - 05:12 AM
freaker
#495
Posted 20 October 2008 - 08:02 PM
sweet, how are the brakes working?Yea sorry it was just me being stupid, all sorted now
the pot joint just didnt click in place properly on the diff output shaft
i went to a second hand spares place they want £35 each per reconed caliper plus an old pair in return a bit steep i think.
