and as for facing off the surfaces, on the hub and where the hose enters the caliper.. is it ok to just use a file or do they ned to milled by a pro..
thanks!
Posted 09 April 2008 - 09:59 PM
Posted 10 April 2008 - 12:45 PM
Posted 10 April 2008 - 02:36 PM
Posted 10 April 2008 - 05:38 PM
im sure i can get 8.4" discs to fit. its the caliper that hits the wheel not the disc.8.4's wont fit under 10's unless you use a masssssssiiiivvvvveee spacer or those jap wheels...
Posted 13 April 2008 - 09:38 PM
Posted 26 May 2008 - 07:09 PM
C**p. I knew my D1s wouldn't fit but I just assumed the Specials would. New wheels then. . .the wheels are 10" mini special alloys and its NO where near even close to fitting.
Where have people sent the calipers off to get re-built? (new pistons and seals)
And how much should i expect to pay?
Posted 26 May 2008 - 08:48 PM
Posted 04 June 2008 - 02:38 PM
Posted 04 June 2008 - 02:57 PM
Posted 04 June 2008 - 03:00 PM
Posted 04 June 2008 - 03:49 PM
Posted 04 June 2008 - 03:55 PM
Posted 04 June 2008 - 03:58 PM
if i can get the caliper to fit then an 8.4" disc will run through the caliper nor problem . there is more than enough space for a bigger disc to run through.
as it stands the 7.9" disc has the pads hanging over the edge. so an 8.4" will fill it much better, therefore more pad surface on the disc and theoretically better braking.
Posted 07 June 2008 - 06:21 PM
Posted 07 June 2008 - 06:38 PM
