Mk1 fiesta caliper conversion
562 replies to this topic
#346 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 30 May 2007 - 08:47 AM
it is because your running metro flanges and have moved the wheels out 10mm each side so the steering arc is increased a little,
You maybe able to trim the leading edge of the wing/arch a little?
It isnt a major problem really but the sportspack minis had steering lock stops built into the rack to limit the lock so they didnt foul the arches or wings.
These maybe an idea if your very concerned????
So if I drop an inch off the wheel width and run 10x5 with the same offset as my 10x6 GB it should give a bit better clearance? save cutting the wing?
#347 $way
$way
  • 720 posts
  • Local Club: ...
Posted 30 May 2007 - 01:14 PM
im looking for getting hoses made up now and have a favour to ask.
can people who have had custom hoses made up post where you had the hoses made, a desrciption on hose length and the fittings and a price if possible?
its not really a big ask and im sure it will help many other people who do this conversion, a bit like the wheels/caliper list but for the hoses.
cheers
J
#348 Gr4h4m
Gr4h4m
  • 1,802 posts
Posted 30 May 2007 - 01:21 PM
cheers
J
Parts from Tweeks;
Built by Mark Rally
Got them from his house :proud:)
Well Mark got the parts from Tweeks and made them up (2x Banjo, 2 X mini subframe connections and hose). They cost about £50 and use the banjo on the caliper end the vid shows the length (I think it was 32CM including the fittings) and how to make sure that they seal on the caliper.
I read in minimag that there is a dude in the US selling a full conversion...
#349 Gr4h4m
Gr4h4m
  • 1,802 posts
Posted 30 May 2007 - 01:25 PM
KAD sell the steering rack limiters for about £8 I believe.
mmm Just emailed KAD.....
Edited by Gr4h4m, 30 May 2007 - 02:03 PM.
#350 $way
$way
  • 720 posts
  • Local Club: ...
Posted 30 May 2007 - 10:29 PM
nice one graham, i hadnt actually watched the video before now, its very good.
now i know exactly what i need for my hoses. are they easy to make up yourself? ive looked at the instrucitons purtsi posted earlier in the thread but dont really follow them...
i have 6x10 wellers but i have a removeable front and its off at the moment so im not sure if my wheels will foul on the wing now...
J
#351 $way
$way
  • 720 posts
  • Local Club: ...
Posted 05 June 2007 - 08:19 AM
i think ill be ordering my hoses from goodridge but i would like to know if you need any special tools to make them at home? or will goodridge supply them pre-made?
J
#352 Purtsi
Purtsi
  • 417 posts
  • Local Club: Mini Club Flying Finns
Posted 05 June 2007 - 12:08 PM
You don't need any special tools when assembling the hoses. What you'll find in your garage is enough :D Just follow the instructions and you can't fail.
#353 $way
$way
  • 720 posts
  • Local Club: ...
Posted 06 June 2007 - 09:49 AM
cheers purtsi.
will phone goodrodge 2moro
#354 mini_kel
mini_kel
  • 2,851 posts
  • Local Club: EMC/No pub mini club
Posted 07 June 2007 - 12:46 PM
Try Rally design, Much cheaper
#355 $way
$way
  • 720 posts
  • Local Club: ...
Posted 14 June 2007 - 11:52 AM
ive finally sorted my life out and got some hoses.
i got them through rally design, they made them up for me too. 20* extended banjo on the fiesta end, stainless braided hose, 320mm end to end, little under £40.
here's the best bit... i ordered them at about 2:30 pm yesterday and they turned up at my house at 9:30 this morning.
cant recommend them enough.
#356 $way
$way
  • 720 posts
  • Local Club: ...
Posted 14 June 2007 - 12:14 PM
they are the perfect length, im just a little unsure about the copper washer sealing against the caliper face.
marc or graham, which cutter did you use and where can you get them from?
cheers
#357 $way
$way
  • 720 posts
  • Local Club: ...
Posted 14 June 2007 - 06:40 PM
dont worry ive sorted a cutter now, just need to get a bush made to fit in the caliper to locate the cutter.
#358 Purtsi
Purtsi
  • 417 posts
Posted 14 June 2007 - 07:41 PM
And here's something totally different on behalf of my finnish Mini friend! =)
Attached File  IMG_2262.JPG   149.97K   81 downloads
Attached File  IMG_2263.JPG   177.87K   74 downloads
Attached File  IMG_2272.JPG   203.25K   84 downloads
Attached File  IMG_2273.JPG   216.02K   107 downloads
Yes, those are Fiesta brake calipers, but this conversion is made so that you use your existing brake drum hubs + mini flanges + Fiat 127 brake disc + bespoke "metal thingie" (pic) :wacko:
A waaaayyyyy cheaper brake disc conversion than what we have done here lol. People who are racing in Mini 1000 Cup here in Finland have been using this conversion over 10 years now and I found out about this few days a go. There are a bit metal work involved, but not much more than this other setup i think. Clever stuff huh? :(
#359 bert998
bert998
  • 2,558 posts
Posted 14 June 2007 - 11:41 PM
ooooh, interesting :wacko:
#360 $way
$way
  • 720 posts
  • Local Club: ...
Posted 15 June 2007 - 11:37 AM
looks good
i have added up the cost of my conversion, calipers, hubs, discs and hoses and it came to £97.
not bad for decent disc brakes under 10" wheels.
