Mk1 fiesta caliper conversion
562 replies to this topic
#286 Purtsi
Purtsi
  • 417 posts
  • Local Club: Mini Club Flying Finns
Posted 15 March 2007 - 11:42 AM
My vote goes to banjo :shifty: Thanks by the way to that person who earlier had the idea to use that instead of straight connector... =)
#287 $way
$way
  • 720 posts
  • Local Club: ...
Posted 15 March 2007 - 02:24 PM
Well I must admit I like the banjo idea looks much less of a bend on the hose, but Mark did prep the caliper to make sure they seal.
the recess face on my calipers is suprisingly tidy.
i dont think ill bother filing the whole lot away though, only enough to get the banjo on.
so where should i order them? (i think ive asked this about 1000 times but hey)
good ridge? moquip? rally design (aeroquip stuff)?
purtsi you siad they are as long as standard mini hoses, what is this? are they fine lock to lock as well?
J
#288 Purtsi
Purtsi
  • 417 posts
Posted 15 March 2007 - 02:50 PM
Well, I've used Goodridge parts and those are superb. I believe that you can order those from your local speedshop. Their website might have their reseller contact details.
I actually remembered to measure the lenght of the hose (just hose, no connectors included) and it was 26cm in the original goodridge hose. I belive that few centimeters more won't do any bad there if you want to be sure. I tried to turn the wheels lock to lock and the lenght was enough and the hose didn' bent too much.
#289 Bchem
Bchem
  • 20 posts
  • Local Club: MSC
Posted 15 March 2007 - 07:09 PM
You will need to measure the fiesta disc diameter, The mk2 and mk3 look exactly the same but the mk2 ones we ned to use runa a 220mm disc,
1600 cc mk2 fiesta and all mk3 ran 240mm diameter which do not fit as i tried on Grahams hubs plus the piston diameter is too big aswell. but disc size is the easy way to confirm suitability for conversion to fit mini.
Thanx mate, without this i would be stuck with mk3 calipers.
Phoned the guy, and the discs were 239 mm, so that are mk3 then i guess.
The search continues...
#290 $way
$way
  • 720 posts
  • Local Club: ...
Posted 15 March 2007 - 09:30 PM
might get 20* extneded banjo 270mm hose and normal bulkhead then.
cheers
J
#291 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 16 March 2007 - 03:40 PM
banjo's etc can be bought from demon tweeks
#292 Purtsi
Purtsi
  • 417 posts
Posted 16 March 2007 - 05:37 PM
Here are few pics more:
This is how it looks when wheel is turned full right:
Attached File  IMG_2898.jpg   477.7K   120 downloads
And this is for $way =)
Attached File  IMG_2899.jpg   820.52K   72 downloads
#293 $way
$way
  • 720 posts
  • Local Club: ...
Posted 16 March 2007 - 08:24 PM
yeah it looks tidy, i think ill do the banjo then.
cheers for the picture of the length, id call it 265mm to be on the safe side.
i think ill phone goodridge/rally design on monday.
cheers buddy
J
#294 oSh
oSh
  • 12 posts
Posted 16 March 2007 - 11:57 PM
had a quick scan but couldnt find it so im going to ask...
What size are the mounting bracket bolts, as i have mislaid mine :D
thanks
#295 Prawn
Prawn
  • 938 posts
Posted 20 March 2007 - 01:28 PM
has anyone else tried this setup with a servo yet?
when i did mine, i was the only person to have tried them with a later mini and a servo!
took the mini out the other day, and the brakes are amazingly sharp, and being so light, the wheels lock up so easily!
i changed to the fiesta setup over metro 4 pots, and they really are awesome :(
#296 Purtsi
Purtsi
  • 417 posts
Posted 20 March 2007 - 02:43 PM
I have thought about a servo as I have a spare metro one. But the amount of work to make that one working would be just too much. And the gain from servo isn't worth that trouble at the moment.
#297 macko
macko
    Starting My Mini Up
  • 2 posts
Posted 25 March 2007 - 12:12 PM
Hi
After switching to fiesta breaks - how far does the wheel sticks out from the front wings?
I have 10x6 revos and I was wondering if the wheels will be covered by group 2 arches (1.75" width)
thx
macko
#298 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 25 March 2007 - 12:22 PM
the same as a 8.5 disk set up
your going to need grp 2 extra wide i think
#299 mini13
mini13
  • 3,810 posts
Posted 25 March 2007 - 03:34 PM
with the recess that fouls the banjo, is it possible to just use 2 or 2 copper washers under the banjo so they sit just proud of the recess?
#300 Purtsi
Purtsi
  • 417 posts
Posted 25 March 2007 - 04:44 PM
Well why not.. But I'd rather file the recess down enough since it's so easy job to do.
