Mk1 fiesta caliper conversion
562 replies to this topic
#181 bert998
bert998
  • 2,558 posts
Posted 13 February 2007 - 01:49 PM
A chap on finity reckons he's used a single hose off the metro set up. Can anyone shed any light on this, anyone know anything about the threads on the metro brakes?
#182 $way
$way
  • 720 posts
  • Local Club: ...
Posted 13 February 2007 - 02:38 PM
If i have understood right, the connectors will be tighten over the hose and inside the connector, there's a "pearl" which holds the hose in place and prevents leaking.
by the way. look at the goodridge catalog. Lot of different kind of connectors and hoses there.
edit: look at the chapter 10. There are assembly instructions :gimme:
This post has been edited by Purtsi: Today, 12:49 PM
ok cheers mate.
EDIT file damaged. the pdf doesnt work for me...
no idea must be m10x1 if it works, who is the user ill pm him on minifinity?
J
Edited by $way, 13 February 2007 - 02:39 PM.
#183 $way
$way
  • 720 posts
  • Local Club: ...
Posted 13 February 2007 - 02:51 PM
PM sent
ill post any reply in here.
J
#184 markrally
markrally
    Z Cars
  • 1,378 posts
  • Local Club: Miniaddicts.co.uk
Posted 14 February 2007 - 09:30 AM
You may be able to utilize a metro pipe but the banjo bolt will be different, Metro is 3/8" UNF and fiesta is M10x1.0 and dont forget to get the correct length banjo bolt as there is 2 lengths depending on which banjo you fit as you need at least 4-5 threads in the caliper after you have fitted copper washers both sides.
#185 bert998
bert998
  • 2,558 posts
Posted 14 February 2007 - 11:23 AM
sounds like a plan :(
#186 $way
$way
  • 720 posts
  • Local Club: ...
Posted 14 February 2007 - 12:18 PM
ive just had a reply from the guy on minifinity.
Hello mate what i had on my car was metro 4 pots and i removed the cailpers and fitted ford ones i took the link pipe off and fitted the banjo on the end of the pipe and the banjo bolt fitted the cailper (the cailpers came from a MK2 fiesta)
so the banjo bolt must have been m10x1...
#187 bert998
bert998
  • 2,558 posts
Posted 14 February 2007 - 12:22 PM
looks like it might be worth buying a full metro set up then if your considering this conversion. :(
#188 $way
$way
  • 720 posts
  • Local Club: ...
Posted 14 February 2007 - 12:24 PM
yup.
#189 $way
$way
  • 720 posts
  • Local Club: ...
Posted 14 February 2007 - 02:35 PM
just had a look at brake unions in the gpr catalogue ive got. which do i want out of concave or convex seat unions?
#190 bert998
bert998
  • 2,558 posts
Posted 15 February 2007 - 11:14 PM
whats the thread on the mini caliper? 3/8 unf?
#191 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 16 February 2007 - 12:32 AM
Yep
#192 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 16 February 2007 - 01:22 AM
demon tweeks sell m10x1 banjo bolts only a few quid each
#193 $way
$way
  • 720 posts
  • Local Club: ...
Posted 17 February 2007 - 02:47 PM
ok i mocked the assembly up yesterday, i havent turned my discs down yet so it wasnt a great mock up, but i found the disc sits towards the outside of the car and not in the middle of the mounting bracket.
has anyone else found this with mkII's?
i plan to face of the inside of the drive flange so the disc sits further inside, its only like 1.5-2mm. nothing drastic.
hopefully will be getting hoses once its all bolted up in place.
J
#194 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 17 February 2007 - 08:43 PM
J
yep we have found the same a small washer spaced the caliper bracket spot on. We haven't finished the mock-up yet but we have everything ready now, all of the old parts have been degrease, wire brushed and painted black and man they look cool now... We are creating a small how to vid so will post it when we are done as we are refurbing the hubs too
Edited by Gr4h4m, 17 February 2007 - 08:45 PM.
#195 $way
$way
  • 720 posts
  • Local Club: ...
Posted 17 February 2007 - 09:59 PM
coolcool.
i might do the same then, certainly easier than getting on a lathe at college.
might face the dirve flange off at a later date just to make it all flush and lovely...
