Mk1 fiesta caliper conversion
562 replies to this topic
#166 $way
$way
  • 720 posts
  • Local Club: ...
Posted 12 February 2007 - 09:59 PM
Remember that I will buy these hoses and fittings from Finland, I bet that u get those cheaper in UK wink.gif. And i'm going for the braided ones if possible:)
LOL! didnt realise you were in finland, haha dont worry about it then.
Banjo's require a good face to seel against and if your using recon calipers that face is often milled back meaning the recess may be too small.
yes this is what im worried about, my calipers arent recon but the face is a little scabby, i was thinking it would be ok to clean it up with alumnium oxide paper. but im not sure if the copper washer will be thick enough to fill the recess...
graham how close are you to fitting the hoses you will have to let us know.
Im using a 90 deg union where its going into the caliper.
where from? i havent been able to find any m10x1 90* unions. have you got a picture of your set up? where did you get the hoses made?
J
#167 markrally
markrally
    Z Cars
  • 1,378 posts
  • Local Club: Miniaddicts.co.uk
Posted 12 February 2007 - 10:22 PM
J
With regards to using the banjo fittings i have a small cutting tool which we use at work for facing off a small circular area around a hole with a hand drill so i am maching grahams to ensure a perfect seal but i have been able to acheive a good seal on a non recessed caliper with a smooth file and then finish it off with some wet&dry papaer wrapped arond the same file and polish it up smooth (put some grease in the hole to stop the metal going inside the caliper then remove it when done)
Will post some pics this week to show what i mean.
#168 $way
$way
  • 720 posts
  • Local Club: ...
Posted 12 February 2007 - 10:36 PM
i think i understand what you mean.
but will the copper washer be thick enough to fill the recess once its been faced?
J
#169 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 12 February 2007 - 10:49 PM
J
The cutter is large enough to remove the recess and our banjo will clear it anyway as it has a slight bend in it, but you can always run 2 washers under the banjo as it will seal when torqued up anyway.
#170 $way
$way
  • 720 posts
  • Local Club: ...
Posted 12 February 2007 - 11:03 PM
ah, are you cutting the whole recess out so it is just a flat face?
2 washer would work yeah.
are you using a 20* union then?
J
#171 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 12 February 2007 - 11:29 PM
J
Yes,
Yes &
Yes!!!
cheers
#172 bert998
bert998
  • 2,558 posts
Posted 12 February 2007 - 11:31 PM
you sound like my neighbour mark :gimme: :D
#173 $way
$way
  • 720 posts
  • Local Club: ...
Posted 12 February 2007 - 11:43 PM
Yes,
Yes &
Yes!!!
cheers
haha, ok cool, might think about doing that to mine then, get the grinder out lol.
#174 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 13 February 2007 - 12:36 AM
Well done Mark..... :gimme: got some bad news on one of the hubs.... sent you an email might slow us down a bit :D
#175 Purtsi
Purtsi
  • 417 posts
  • Local Club: Mini Club Flying Finns
Posted 13 February 2007 - 08:19 AM
Just visited the local speedshop. They said that they don't make brake hoses but they can supply Goodridge hoses and connectors that I can assemble myself. All the parts together should be about 70€.
#176 Gr4h4m
Gr4h4m
  • 1,802 posts
Posted 13 February 2007 - 09:28 AM
thats what we are using....
#177 $way
$way
  • 720 posts
  • Local Club: ...
Posted 13 February 2007 - 12:08 PM
how hard are they to make up?
this is probably a cheaper way of doing it so, im all for it.
J
#178 Purtsi
Purtsi
  • 417 posts
Posted 13 February 2007 - 12:51 PM
I believe it's just cutting the hose in to correct lenght and attaching the connectors. That should be it. pls correct me if I'm wrong.
#179 $way
$way
  • 720 posts
  • Local Club: ...
Posted 13 February 2007 - 01:33 PM
well thats obvious lol.
how do the connectors actually fit to the hose?
#180 Purtsi
Purtsi
  • 417 posts
Posted 13 February 2007 - 01:48 PM
If i have understood right, the connectors will be tighten over the hose and inside the connector, there's a "pearl" which holds the hose in place and prevents leaking.
by the way. look at the goodridge catalog. Lot of different kind of connectors and hoses there.
edit: look at the chapter 10. There are assembly instructions :gimme:
Edited by Purtsi, 13 February 2007 - 01:49 PM.
