Mk1 fiesta caliper conversion
562 replies to this topic
#136 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 05 February 2007 - 10:35 AM
Getting my 8.4" setup on wednesday.
Just need disc driveshafts, metro turbo drive flanges, fiesta calipers.
I've got some adpaters for the brake lines made up, but i'm looking at this banjo bolt idea too.
When Mark and I were looking at the F-caliper (I have MK2 but I think the MK1 is the same) the brake hose connection sticks straight up out of the caliper, this would mean the hose would need to be bent in an S to reach back to the mini subframe mount.
From what I have seen some people have extended the metal pipe to mount on the inner wing or as Mark was saying you could come off of the caliper at a right angle with a banjo fitting so the pipe follows the same route as the old mini one and will be less likly to foul anything.
#137 $way
$way
  • 720 posts
  • Local Club: ...
Posted 05 February 2007 - 10:57 AM
this is probably what i will be doing when i get my hoses made up. banjo on the festa end.
#138 markrally
markrally
    Z Cars
  • 1,378 posts
  • Local Club: Miniaddicts.co.uk
Posted 05 February 2007 - 08:47 PM
I have just got Gr4h4ms fitting for him today, a little more expense than was planned :( but the end result should be a lot better.
here are both ends...........
Attached File  bulk.jpg   12.57K   14 downloads
Attached File  banjo.jpg   12.36K   14 downloads
If you look on miniaddicts.co.uk and go into the forum and look at he video section soon, a full detailed video will be available showing what is involved etc.
#139 Gr4h4m
Gr4h4m
  • 1,802 posts
Posted 05 February 2007 - 10:32 PM
I have just got Gr4h4ms fitting for him today, a little more expense than was planned :ghost: but the end result should be a lot better.
ooooooooo shiny :( I take it I owe you some more money???
#140 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 05 February 2007 - 10:39 PM
No, but i was expecting to get the pads aswell originally in my pocket money allowance!!! You got enough change for a pint tomorrow. :ghost:
cheers
#141 $way
$way
  • 720 posts
  • Local Club: ...
Posted 05 February 2007 - 11:01 PM
what are the fittings? need to confirm before i get some hoses made...
m10x1 banjo festa end? not sure what the mini end is?
did you just get the fittings or did you get the complete hoses made up?
how long are they supposed to be?
J
#142 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 05 February 2007 - 11:18 PM
J
3/8" x 24 (UNF) for the mini bulkhead end,
Im making it up once the calipers are mounted on the car as its cruical to have the flexi's not fouling any steering or driveshaft etc.
will let you know the length when the jobs done soon.
#143 Pickup76
Pickup76
    Ring Runner 2005
  • 1,191 posts
Posted 06 February 2007 - 12:01 AM
For my hoses i made up custon braided jobbies with a 90deg fitting at the caliper end. They dont foul anything and i didnt have to move the brake lines! Tad on the expensive side tho :(
#144 $way
$way
  • 720 posts
  • Local Club: ...
Posted 06 February 2007 - 12:05 AM
cool cheers mark...
when will they be done as ill be wanting mine making up very soon. once you know the length and have finished the hoses for graham would you be able to make up another set? could you give me a price etc.??
pickup76 where did you get them from and how expensive is expensive?
J
#145 Pickup76
Pickup76
    Ring Runner 2005
  • 1,191 posts
Posted 06 February 2007 - 12:16 AM
I got mine direct from moquip but i only bought the bits and made it all up myself. Bits came to about £30 if i remember correctly.
#146 bert998
bert998
  • 2,558 posts
Posted 06 February 2007 - 12:18 AM
merlin quoted me about £40 for my hoses :S
#147 $way
$way
  • 720 posts
  • Local Club: ...
Posted 06 February 2007 - 11:53 AM
i might try rally design apparently they are cheap....
will let you know what the quote is.
ciao
#148 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 06 February 2007 - 10:27 PM
i found some new mk2 calipers which are suitable herecaliper lh and here rh caliper
cheers
#149 $way
$way
  • 720 posts
  • Local Club: ...
Posted 07 February 2007 - 01:22 PM
cool,
mark how much would it be for you to make me up two hoses?
J
#150 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 09 February 2007 - 04:25 PM
cheers
problem with those mark is that they dont have the mounting brackets which are hard to get hold of seperately
