Fitting New Rear Brake Shoes.
21 replies to this topic
#16 gazza01
gazza01
  • 644 posts
Posted 11 July 2013 - 10:43 AM
sounds odd...
with the adjuster wound fully out you'd expect them to be an easy fit.
Are the adjusters on a flat?
Are the handbrake levers (in the drum) pivoting freely?
Squeeze the pistons together, to make sure they have backed off.
Take the clevis pins out of the brake cables if your are in any doubt about the handbrake not being fully off.
The shoes should go on with the unlined end at the bottom on the shoe nearest the back of the car and on top for the front shoe.
not according to the haynes. unlined end top/nearest back of car. lined end bottom for shoe nearest front of car pg173  4.15
#17 lrostoke
lrostoke
  • 6,923 posts
Posted 11 July 2013 - 10:54 AM
It's an old topic but this is how they go
#18 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,157 posts
  • Name: Sean
Posted 11 July 2013 - 11:04 AM
As above but I remember it as
"Gap in direction of travel"  The gap at the end of the shoes is in the direction that wheel rotates!!
(I have a weird memory!!)
#19 tiger99
tiger99
  • 8,584 posts
Posted 12 July 2013 - 02:38 PM
I don't see how they could be fitted incorrectly, as the handbrake mechanism has to fit into the holes for it, and if they are transposed it is not going to want to fit. But someone will no doubt find a way to get it wrong!
That is obviously not the case here, as the shoes must really be the wrong size. I do remember a pair that were rather tight at first, but they usually come good after pressing the pedal and pulling the handbrake really hard to force the shoes to centralise themselves properly. But this seems to be yet another case of declining product quality, of which we are seeing more these days. I suspect that the shoes that don't fit have been made to metric dimensions, or something equally stupid.
#20 Rorf
Rorf
  • 866 posts
Posted 29 May 2018 - 12:20 PM
You'd be surprised, they can be put on incorrectly by a ham fisted operator. The part of the shoe which has the larger exposed metal part is called the leading edge of the shoe. The diagram is a perfect explanation.
#21 Spider
  • 15,871 posts
Posted 29 May 2018 - 08:05 PM
I'd say just about every Mini & Moke I have bought or worked on when a friend bought one over the past 10 odd years, had at least one or both sides back to front.
#22 andyapanel
andyapanel
  • 651 posts
Posted 30 May 2018 - 12:39 PM
I have had this problem
Eventually, I removed the new shoes and held them against the ones I had removed. The lugs either end were slightly too long.
They were a good make-Ferodo or Unipart and it was before the flood of poor quality rubbish.
