Air in clutch
Posted 04 May 2005 - 06:19 PM
So for a spot of fun I replaced my entire clutch hydraulic system over the past few days because i couldnt get the thing to bleed properly, there was always air in it. new m/c, slave cylinder, and both hoses. Did the final hose today thinking that was sure to cure it. The shotgun approach to diagnostics or what! Anyway the bugger still has air in. Im using a one-man bleed tube thing and i can only guess that this is cream crackered. Before I fork out cash I dont have to a garage, any last ideas?
Posted 04 May 2005 - 07:24 PM
Posted 04 May 2005 - 07:58 PM
or...
There's an ezi-bleed which is a pressurised cannister connected to your tyre and maste cylinder which forces the fluid through.
The first, I've found, are basically kack, as you can't see what's comming out of the end, when you're pumping the pedal so you need two people, and if there is any degredation in the one way valve, air is sucked back in.
The ezi-bleed, is superb, and I've used one for years with no troubles.
Posted 04 May 2005 - 08:24 PM
Like said before, try bleading it manualy. If you've got long arms and legs like me, you can do it yourself by having the boor open and leaning thru the gap between the door and body while pumping the peal and do the blead nipple.
Failing that, wedge the clutch pedal down with the nipple closed off and leave it for a day or so, this way and air in the system should work its own way out.
Posted 04 May 2005 - 09:18 PM
This makes it a one-man process and fairly quick also.
Posted 04 May 2005 - 09:47 PM
By the by I've heard however that those eezibleed jobs can pop seals when you use them on brake systems, particularly on vauxhalls?
Posted 05 May 2005 - 04:42 PM
You'll need to have blead the system a bit befor you do this mind.
Wil
Posted 05 May 2005 - 04:53 PM
That way you don't have to use the pants one man bleeding kit. Alternatively do what Guessworks and others have suggested and acquire an eezi-bleed kit.
Tom
Posted 05 May 2005 - 05:18 PM
Posted 05 May 2005 - 05:27 PM
Posted 05 May 2005 - 07:10 PM
Any takers?!something to look out for...dodgy nipples
Posted 05 May 2005 - 07:25 PM
ahem
anyway big thanks lads as soon as i plugged in eezibleed that lovely tube full of bubble-free fluid that ive been dreaming about appeared.
so chances are it was my tube which was knackered in the first place (oo-er) and i didnt need to renew all those parts....GRRRR....let this be a lesson to others because i feel like a bit of a retard now!
However the beggar still wont go into 3rd or 4th without screaming and graunching so i reckon ive dropped another bollock somewhere else...maybe using an A series gearchange rod with an A+ gearbox and an A+ quickshift stick wasnt a good idea? i didnt think it would make any difference. or perhaps just time to adjust the clutch whatnot properly?
Posted 06 May 2005 - 11:16 AM
Posted 06 May 2005 - 12:00 PM
