Moved to FAQ
Posted 30 March 2008 - 07:19 AM
Posted 30 March 2008 - 12:18 PM
Posted 30 March 2008 - 02:00 PM
Posted 06 April 2008 - 11:42 AM
Posted 04 May 2008 - 02:36 PM
Posted 08 June 2008 - 08:16 PM
Edited by THE ANORAK, 08 June 2008 - 08:17 PM.
Posted 08 June 2008 - 09:56 PM
Posted 13 June 2008 - 06:51 AM
Posted 31 August 2008 - 11:57 AM
just to answer this (although a little late) yes you really should fit 5mm spacers on the rear hubs when using 165 tyres on the rover alloys otherwise the side wall of the tyre will rub on the radius arm during hard cornering due to the small offset of the wheel.
all the rover wheels i know of are 4.5 wide, although the cooper brochure that the accessory pack comes from stated that they are 12x5 ????
not sure on this but i will update if i find out any more
Posted 31 August 2008 - 05:29 PM
Just a thought about the quantity which was mentioned in the letter... and this is in no way a dis' on the excellent write up by "The Anorak"
Most of the photo's where the nuts are inline with the spokes are promotional photo's, therefore taken before the vehicle was available to the general market. Is there not a possibility that even though shown on the picture, the wheel may have been changed before or during the production run ?
I also had a 30 which had a harlequin set ( two of each )
The wheels in the Cooper kit were 12x5 and predated the Rover wheels (the Rover may have even been copies of these). IIRC they were made by a company called Cromadora or something similar.
The spacer issue is a little cloudier, when the 165 tyres were first launched as part of the cooper handling pack (4 tyres, 4 spax dampers, rear 5mm spacers) it was stated that the spacers were to clear the larger dampers. To back this up the factory cars that wee fitted with 165 tyres as standard didn't have spacers fitted. Also, the S converted cars (not S pack) from Cooper garages had 165 tyres and Koni dampers but no spacers.
Edited by THE ANORAK, 31 August 2008 - 05:32 PM.
Posted 01 September 2008 - 05:32 PM
well regardless of what the factory cars were fitted with, I'm still recommending spacers on all rover minilite style alloys with 165 tyres, the clearance is just too small without them
and I'm talking about cornering HARD
thank you miniholic, welcome to the forum
Posted 30 September 2008 - 05:30 PM
Posted 30 September 2008 - 06:22 PM
Posted 01 October 2008 - 03:12 PM
Posted 01 October 2008 - 06:09 PM
You've got a choice of two sizes, the original factory fit 145/70r12 or the upgraded 165/60r12. The latter were fitted to a few factory special editions then became standard fit on the Cooper from the 1995 model year.
I would go for Yokohama personally as I've found them to be better than the slightly cheaper Falkens, especially in the wet.
