Where can I source new bleed nipples (8.4 in std disc set)? Mini spares only stock them for the drum setup, but having removed one from an old front drum it appears identical to the one used in the calipers. I also need to replace the bolt that goes through the tie rod and lower arm which has a plain shank and threaded end, these are not listed either.
New Caliper Bleed Nipples?
AngeloEvs
, Mar 25 2008 06:21 PM
1 reply to this topic
