low oil pressure
Posted 27 April 2005 - 08:04 PM
thanks in advance. Leonard
Posted 27 April 2005 - 08:25 PM
Also the oil light on a standard mini comes on about between 7 and 10 psi which is already staving the live blood out of the engine...
If after an oil change you're still experiencing low oil pressure, then bottom line s the engine comming out the car, it could be oil pump, but more likely Mains or Big ends, certainly if the engine is a high miler.
Posted 27 April 2005 - 08:41 PM
Posted 27 April 2005 - 08:58 PM
One thing to do would be to remove the domed nut on the front of the engine and the spring and oil pressure release valve just to make sure there no swarf holding it open...
Edited by GuessWorks, 27 April 2005 - 09:01 PM.
Posted 27 April 2005 - 09:10 PM
Posted 27 April 2005 - 09:17 PM
You can change the oil pump with the engine in but the majority of the side of the engine has to be removed for this to be accomplished..
So the clutch / flywheel and flywheel housing needs to be remove. You will then have access to the pump.
Posted 27 April 2005 - 09:53 PM
Posted 27 April 2005 - 10:45 PM
Posted 28 April 2005 - 03:47 AM
Start with an oil change to fresh 20W50 and a new filter. That may help some but you'll probably find it still drifts too low the more you drive it and the hotter the engine gets. Since you plan on pulling the engine this summer anyway, you could take the bandaid approach and run a thick oil additive to keep the viscosity up. It's not a good solution but it may help limp you through until summer. Make sure you keep the oil level on the high side for maximum capacity and if possible limit your drives to shorter trips where the engine doesn't have time to get too hot.
Posted 28 April 2005 - 09:08 AM
Posted 28 April 2005 - 12:18 PM
Remember the two numbers (i.e. 20 & 50 in 20W50) represent the equivalent viscosities when cold and hot respectively. This means 20W50 will act like straight 20 weight when cold and 50 weight when hot. If you run 10W40 the oil is thinner acting both when cold and hot. That's not going to help a low oil pressure reading.
Posted 28 April 2005 - 09:22 PM
unfortunately, its my only car and i do long journeys twice a week. ive also got a 5 hour drive to north wales in the summer before my new engine, so hopefully this one will last! if need be i can whip out the engine and do an oil pump change one weekend.
Posted 29 April 2005 - 01:50 AM
If pulling the engine out and putting a new pump in is a casual weekend job for you then I would certainly try this if the basic checks don't reveal anything. For me, that's major surgery involving borrowing equipment and fitting tasks into a cramped schedule.
Posted 29 April 2005 - 05:15 PM
Posted 29 April 2005 - 06:26 PM
