R1 powered Mini Cooper
#286
Posted 25 November 2005 - 10:50 PM
If i mount mine on the mini box section at the front the seats are a litt too high even on the lowest setting on the subframes so i was considering lowering the box section and rewelding it in back in and using 1" box tubing braced between the sill and tunnel for the rear mount.
cheers Mark :wales:
#287
Posted 25 November 2005 - 11:40 PM
If I remember rightly most of the steel bodied z-car mini have the box section left in because even with it in the floor sags alot. I'm sure you could make it smaller so you can mount the seats lower but I don't remember anyone else having to.
I had mine removed as the seats never would have fitted with it still in place!
What seats have you bought? Are they different to the usual suspects? ie cobra monacos imolas etc etc
#288
Posted 26 November 2005 - 12:21 AM
I was just going to lower the box section an inch or so by cutting the top off and removing an inch off the sides and welding the top on again.Hi Mark
Here are the seats..............
Mark :wales:
Posted 26 November 2005 - 08:18 AM
#290
Posted 26 November 2005 - 10:53 AM
#291
Posted 26 November 2005 - 10:55 AM
#292
Posted 26 November 2005 - 11:00 AM
#293
Posted 26 November 2005 - 11:04 AM
#294
Posted 26 November 2005 - 11:44 AM
Is that your car in the early stages?? It doesnt look like it!!!!Ianother..
I could live with the height as it is but when i put my helmet on aswell it is touching the roof so no good for the trackday's!!!!!!!
I cant lower the back of the seat anymore on the subframes as the base of the seat is level with the bottom of the subframe, even though i could drill holes lower down.
Ollie if i put it further back on the floor i cant reach thew gearstick, you must have arms like mr tickle
Mark :wales:
#295
Posted 26 November 2005 - 11:51 AM
He will be starting his own post soon..
Have you got the normal length gearstick? If so, you can bend it quite easily
#296
Posted 26 November 2005 - 12:01 PM
MArk :wales:
#297
Posted 26 November 2005 - 12:05 PM
#298
Posted 26 November 2005 - 12:08 PM
#299
Posted 26 November 2005 - 12:22 PM
#300
Posted 26 November 2005 - 12:25 PM
