R1 powered Mini Cooper
#256
Posted 22 November 2005 - 11:14 PM
#257
Posted 23 November 2005 - 01:06 AM
Mark :wales:
Posted 23 November 2005 - 01:07 AM
MArk :wales:
Posted 23 November 2005 - 06:23 PM
Mine weighed 609 kg. The shell is all steel and it's fully carpeted. It also run's a servo which I believe your doing away with. I know of another that is fitted with a zeemax kit and that only wieghed about 650 kg. Your's should end up around the 600 mark.
Pete
#260
Posted 23 November 2005 - 06:24 PM
Have you checked to see if you are getting full throttle??
Any more piccies of yours??? What have you been up to??
#261
Posted 23 November 2005 - 06:35 PM
Here is a piccie of my clutch setup.
#262
Posted 23 November 2005 - 08:10 PM
Very clean i must say. And thanks
#263
Posted 23 November 2005 - 08:14 PM
#264
Posted 23 November 2005 - 08:18 PM
#265
Posted 23 November 2005 - 08:26 PM
Not seen any using a cable either....
#266
Posted 23 November 2005 - 09:03 PM
#267
Posted 24 November 2005 - 08:05 PM
Dale,Pete
Had to modify the throttle links that Chris gave us. If we had fitted them as supplied we would only have got 1/2 throttle. Simply cured by drilling another hole further down the metal shaft. Means the cable comes out of the body and angles down a bit but at least we get full throttle. Put a bit of outer casing over it where it comes out of the bulkhead to stop it catching.
Haven't touched mine since I repaired the engine. I have brought some angled chequer plate to go around the top of the pick-up sides but can't be bothered to fit it. Too cold and wet to go outside.
Pete
#268
Posted 25 November 2005 - 06:42 PM
Mine is putting out 165bhp at the moment. You should be a few bhp more..maybe 170bhp
Have you found the tendancy for Chris not to check things before he sends them out??
#269
Posted 25 November 2005 - 07:00 PM
Cool! Is that at wheels or fly?Ade
I think the only thing from Chris we had to modify was the accelerator assy.
But then I think we had some of the first ones he made.
#270
Posted 25 November 2005 - 07:03 PM
Thats at the flywheel mate!!
