60ft/lb Torque Estimate
Posted 23 March 2008 - 11:27 PM
Some people should be banned from DIY!!! I'm going to pull all four wheels now to inspect them.
But I have a question. I do not have a torque wrench and need a "feel" based estimate as to how tight the crown nut should be.
Can anyone help me out?
Cheers,
Robin
Posted 23 March 2008 - 11:31 PM
Posted 23 March 2008 - 11:34 PM
As the nut is a "tighten to 60 lb then a bit more until the the split pin will fit" its not mega critical, as a tempory measure you could guess it by measuring the bar you are using and vary the effort accordingly, and by temporary I mean this as a get you home effort.
If the bar is say 2 Ft long then you need to guesstimate 30 lb of effort onto the end of the bar, if it is 1ft, 60 lb. if it is 4 ft then 15 lb etc.
Edited by mini13, 23 March 2008 - 11:35 PM.
Posted 23 March 2008 - 11:35 PM
Take your socket wrench handle and slip it into a pipe. Use tape to mark a spot exactly 2 feet up the pipe from the center (drive) of the wrench. Put the wrench horizontally on the nut and position the scale sort of under tape on the pipe. Step on the scale and note your weight. Push up (or pull down) on the pipe while you're standing on the scale. Stop when you see the scale showing a change of 30 pounds (30 pounds x 2 ft = 60 ft-lb).
Posted 23 March 2008 - 11:36 PM
But, torque is just a force (weight) times the distance from the centre of rotation.
DK, that's genius!
Edited by Ethel, 23 March 2008 - 11:38 PM.
Cheers.
Posted 23 March 2008 - 11:57 PM
I think you've highlighted another term that must be in differnt use in the U.K. and the U.S. Over here, a split pin and a cotter pin are the same thing. Can you post any links that would show me which you're calling which?
The link below shows what I would call a cotter pin but I'd just as likely call a split pin:
http://www.toolstati...ebbig/50623.jpg
Posted 24 March 2008 - 01:10 AM
Posted 24 March 2008 - 01:38 AM
Not sure about everybody else but I've always thought of a cotter pin as a tapered peg with a threaded end, normally used to hold a bicycle pedal to the shaft
Posted 24 March 2008 - 02:31 AM
Searching Google Images for "cotter pin", most of the images are what you are calling (rightly) a split pin. Although... some of the images that turn up with those search keywords also show what I call a "hitch pin" and I believe in the U.K. I've heard you guys refer to as an "R clip". If you repeat the same Google Images search with the keywords "split pin" you get the same items as for cotter pin. So... the same thing, just two different descriptions.
Then of course... there's Wikipedia...
http://en.wikipedia....wiki/Cotter_pin
http://en.wikipedia.org/wiki/Split_pin
Edited by dklawson, 24 March 2008 - 02:35 AM.
Posted 24 March 2008 - 08:02 AM
why mess about guessing £16 and you can buy one
http://www.machinema...e-torque-wrench
if one is buying a torque wrench, what is the range it should have? for mini use
Posted 24 March 2008 - 08:29 AM
DaveRob
