1989 1015cc Mini City + Redtop
1203 replies to this topic
#1111 Burnard
Burnard
  • 3,350 posts
Posted 13 October 2010 - 11:48 AM
Ill give u a shoe horn for the minus
#1112 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 13 October 2010 - 01:53 PM
No thanks. If it ever went near the minus it would be RWD no question.
#1113 HARBER07
HARBER07
  • 4,498 posts
Posted 14 October 2010 - 06:17 PM
VAG COP's turned up today
One more thing to tick off the list.
#1114 george91
george91
  • 883 posts
Posted 14 October 2010 - 06:35 PM
keep it! i really wanted to see this finally finished, i think you'll regret it if you sell it unfinished. keep going mate. :)
#1115 HARBER07
HARBER07
  • 4,498 posts
Posted 19 October 2010 - 06:18 PM
Box of stuff received from QED - core plugs, dowels, bolts etc., Z20LET oil pump + seal picked up from the vaux dealers - thieving *see you enn tee ess*!!!. Block sent for machining last week, probs pick it up tomorrow. Just need to get hold of some stainless cap head bolts for various stuff, and order some RTV seal stuff.
For reference some part numbers:
Black RTV stuff to seal the crank cap is: 90485251
Z20LET oil pump: 24402722
Z20LET oil pump pickup seal: 90500908
#1116 Adcuz
Adcuz
  • 843 posts
Posted 19 October 2010 - 06:25 PM
Keeping it then? :D
#1117 HARBER07
HARBER07
  • 4,498 posts
Posted 19 October 2010 - 06:27 PM
Well fingers crossed, touching wood, praise jesus etc. the oil pressure has settled - as in its staying consistent. As long as I don't have to pull the engine for a while then I'll stay friends with it :D
For the time being anyways. Still think it will probably be given up for the Minus eventually.
#1118 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 19 October 2010 - 10:27 PM
Well fingers crossed, touching wood, praise jesus etc. the oil pressure has settled - as in its staying consistent. As long as I don't have to pull the engine for a while then I'll stay friends with it ;)
What sort of preasures u getting?
you've got to keep it long enough for it to have the vaux
#1119 HARBER07
HARBER07
  • 4,498 posts
Posted 20 October 2010 - 02:48 PM
80psi cold idle + driving. 40-50psi hot driving, and 20psi hot idle. It's not changed from that at all though.
Also I've got a spare clutch cover!
#1120 mini_mad69
mini_mad69
  • 5,417 posts
Posted 20 October 2010 - 03:07 PM
Naaa sorry mate, didn't mean the clutch cover.
I mean the bell housing, as in the thing that holds the drop gears and crank seal.
Atleast you've got decent oil preasure now, just enjoy it.
#1121 HARBER07
HARBER07
  • 4,498 posts
Posted 20 October 2010 - 03:08 PM
Transfer case? ;)
Also got one of them!
#1122 mini_mad69
mini_mad69
  • 5,417 posts
Posted 20 October 2010 - 03:15 PM
Transfer case? ;)
Yes transfer case, always get confused, haynes call it flywheel housing.
Yeah how much you want for one of those?
#1123 HARBER07
HARBER07
  • 4,498 posts
Posted 23 October 2010 - 02:39 PM
Bulkhead bracket ripped off :D .
Made a new one up out of 3mm plate, so a bit more beefy than a bent bit of tin. Also added a second top engine steady to support it the other side. Shouldn't go far now!!
Also the machinists are taking their time with the block. Doesn't really bother me, but just explains why there are no pics of engine porn!!
#1124 mini_mad69
mini_mad69
  • 5,417 posts
Posted 23 October 2010 - 03:40 PM
My 1380 did that, and then started pulling the subframe mounts apart!
#1125 HARBER07
HARBER07
  • 4,498 posts
Posted 23 October 2010 - 03:44 PM
Subframe mounts are done. Solid mounted and a big 3mm plate welded inside the car :xxx:
Also managed to lose a bracket thats meant for an ultimate engine steady - probably weighed about 500g :D, was huge!
