1989 1015cc Mini City + Redtop
1203 replies to this topic
#91 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 22 March 2009 - 08:47 PM
Little bit to update with in here too.
Pic of Weber box fitted:
Also attached a sticker i got from Malvern, though im not sure its suitable for the younger viewers :thumbsup:
Edited by HARBER07, 22 March 2009 - 08:48 PM.
#92 sweetser
sweetser
  • 3,995 posts
Posted 22 March 2009 - 08:53 PM
Apparently his mini is the dogs danglies :thumbsup: :ermm:
Mmm you still get fumes :) that was real bad lol
#93 HARBER07
HARBER07
  • 4,498 posts
Posted 22 March 2009 - 08:55 PM
Yeah thats the one Luke :)
And yep i had to take my bro's mate out in it today - he got back saying it stunk of petrol - i just laughed LOL. So yep, still fumes, still bad :thumbsup:
#94 sweetser
sweetser
  • 3,995 posts
Posted 22 March 2009 - 08:58 PM
haha was well funny
#95 HARBER07
HARBER07
  • 4,498 posts
Posted 22 March 2009 - 08:59 PM
From now on i have to drive with ALL the windows open :thumbsup:
#96 mighty mini jack
mighty mini jack
    Mighty Before a Pint
  • 5,095 posts
Posted 22 March 2009 - 09:10 PM
Good stuff Tomass!
#97 HARBER07
HARBER07
  • 4,498 posts
Posted 22 March 2009 - 09:15 PM
Cheers Jack :thumbsup:
#98 HARBER07
HARBER07
  • 4,498 posts
Posted 29 March 2009 - 09:06 PM
Right, ive got some more done today :withstupid: And with the car off the road for a month there should be plenty more!
Started off thismorning pulling out the front wiring loom, as its all burned and melted in places! So its currently nailed to a board ready to be modified and turned into a custom loom.
Then came the usual sit about, deciding-what-to-do-next bit. I ended up chipping off the bitumen sound deadening, to save a little weight (well 10.5kg ;D) and i also found a couple small rust holes underneath, so i can patch that up now.
Next jobs: tidy up the floor, get the custom loom in, re-carpet and order the tyres / brake refurb bits.
#99 sweetser
sweetser
  • 3,995 posts
Posted 29 March 2009 - 09:10 PM
Looking good tom ;D
#100 captainjack15
captainjack15
  • 3,925 posts
Posted 29 March 2009 - 09:18 PM
;D
#101 HARBER07
HARBER07
  • 4,498 posts
Posted 29 March 2009 - 09:21 PM
Just need paying now ;D
#102 HARBER07
HARBER07
  • 4,498 posts
Posted 07 April 2009 - 07:37 PM
Good news! :thumbsup:
Yesterday my Minispares order came, after my bank decided i spent too much and cancelled my card :D, but anyways this lot turned up:
That includes:
Maniflow Stage 2 LCB
Adjustable Bottom Arms
Adjustable Rear Camber Brackets
2x Radius Arm Repair Kits
Rear Subby Rubbers
Offset Bottom Arm Rubbers
4x SS Caliper Pistons
Caliper Repair Kit
Caliper Pad Retaining Kit
Filter King Regulator
Silver Top Facet Fuel Pump
Fuel Pump Unions
4x Weller Centre Caps
19mm Wheel Spacer Set
:wub: :) :wub:
And seeing as the days are longer when i get home after work, it gives me a chance to get a lot more done while its off the road :). So after a bit of decision making, i decided my front floor pans needed replacing, outer sills and doorsteps both sides of the car. So picked up some more panels from DSN (not for the cooper this time!) and set about cutting the old out.
Some nice sod decided it would be OK to put the repair sill over the old sill, so i have 2 to remove now :gimme:
Ive got 7 days off over easter, so i hope to get all the new goodies on and get most of the welding done. then as soon as its solid and i get my pay slip at the end of this month, i can get the engine in!
All good :thumbsup:
Edited by HARBER07, 07 April 2009 - 07:38 PM.
#103 HARBER07
HARBER07
  • 4,498 posts
Posted 13 April 2009 - 09:05 PM
MORE FRIKIN RUST!!!
So yep, a small bit of rust fighting has turned into a mini restoration project :(. I wanted to do a decent job of it, so bought 2x floor repair panels, 2x door steps, and 2x outer sill (to start with :thumbsup:). Found the rear heel board and inner sill it totally shot, as seen above. Welded the full front floor in and door step, after bracing the shell a bit.
Sill is only placed on to check fit & flitch repair.
I have refurbed 2 rear radius arms using the Minispares kit, which i was pretty pleased with :dontgetit: Removed rear subby, to find more rust in boot corner :genius: So ive setup camp out the front of the house, in an old tent ;) . Not exactly fire proof, but it will do me for a couple hours each night when i come home from work.
Just about managed to weld half the O/S boot floor in with genuine rear closer, and strengthening bracket today. No decent pics though.
Jobs To Complete:
Weld inner flitch panel O/S
Weld rear inner sill
Weld heel board O/S
Weld boot floor corner N/S
Weld N/S closer panel
Weld N/S strengthening Bracket
Repair both rear quarter panels
N/S outer sill
O/S outer sill
N/S door step
N/S front floor section
Move power/brake/fuel lines into car
Finish Engine off
Fit engine
Refurb front subby
Fit trick suspension bits
Get & fit tyres
Refurb 8.4" brakes
Fit new fuel pump & regulator
Fit handbrake cable
Get MOT & insurance
DEADLINE 17TH MAY - LONDON TO BRIGHTON!!!
Edited by HARBER07, 13 April 2009 - 09:15 PM.
#104 captainjack15
captainjack15
  • 3,925 posts
Posted 13 April 2009 - 09:12 PM
Nice one Tim Tom, loving that lot of goodies :(
#105 HARBER07
HARBER07
  • 4,498 posts
Posted 13 April 2009 - 09:13 PM
Oh yeah, also ripped off the moulded arches, mainly because the Wellers are way too wide for the W&P's, but also to repair the rear quarters, as the arches just trapped the rust.
See, too wide:
Edited by HARBER07, 13 April 2009 - 09:14 PM.
