1989 1015cc Mini City + Redtop
#1021
Posted 08 September 2010 - 09:38 PM
And yeah it was awsome, want to do it again for longer.
#1022
Posted 08 September 2010 - 09:41 PM
There is a local one, kinda, so might take it down there sometime!
I'd love to go to the ring, but it just seems too expensive
Edited by HARBER07, 08 September 2010 - 09:42 PM.
#1023
Posted 08 September 2010 - 09:52 PM
Yup me too!
I'd love to go to the ring, but it just seems too expensive. Maybe in a couple years with the Vaux engine or
something!S U M M A T
It's not as expensive as I thought. You going to combe?
#1024
Posted 08 September 2010 - 09:56 PM
#1025
Posted 08 September 2010 - 10:07 PM
Nope thats me done this year for shows man. Probably. Now looking at Rivi run next year!
Riv RUn is an awsome weekend. I realy enjoy it.
Whats next for the car though? after 1380 that is.
#1026
Posted 08 September 2010 - 10:22 PM
Then get some solid door frames - which must add the mini door company doesn't actually have any doors!!. After I've sorted 2 solid doors, then i can get the A panel on the N/S, which then allows me to fit the FG front end. Just leaves me the scuttle panel and the boot lid to sort. Then quick blowover paint job. Then build the frame, buy the brakes + suspension shizz for the conversion and start on the interesting stuff.
Also - place your bets as to what I might find inside my current engine!!
#1027
Posted 10 September 2010 - 07:38 PM
block built up and checked - all seems spot on. Also helicoiled the threads where the transfer casing bolts. So hopefully in by the end of tomorrow!
#1028
Posted 10 September 2010 - 11:51 PM
All systems GO!!!
Whats the spec then?
#1029
Posted 11 September 2010 - 06:09 PM
1380
296 scatter cam
isky follwers
40 DCOE weber
steel 5" maniflow inlet
megaojlt
ported 940 head - stage 3 ish??
double valve springs and bronze guides anywho
stage 2 maniflow exhaust manifold
leccy fuel pump blah blah......
oil cooler, adjustable oil pressure shizz.... etc. etc.
Just what I had laying around to be honest
Idles like a *******, but ill do some tuning tomorrow. Got me home anyways.
#1030
Posted 11 September 2010 - 06:15 PM
Whats the spec on the head? stage 3 heads usualy have prerry large valves. I thought you had a standard ported 12g940.
Either way, that spec should move along quite quickly.
#1031
Posted 11 September 2010 - 06:17 PM
#1032
Posted 11 September 2010 - 06:20 PM
#1033
Posted 11 September 2010 - 06:34 PM
#1034
Posted 11 September 2010 - 06:39 PM
#1035
