1989 1015cc Mini City + Redtop
1203 replies to this topic
#451 mighty mini jack
mighty mini jack
    Mighty Before a Pint
  • 5,095 posts
Posted 30 November 2009 - 09:27 PM
The bit you welded on threaded then man?
(give me an afternoon with the frame at college and it could be welded up) :(
#452 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 30 November 2009 - 09:30 PM
Yup, i cut it out the original subframe, made it nice and round, then welded it in the hole. Hard to explain what it looks like unless you cut it out - forgot to get pictures of that :(
#453 mighty mini jack
mighty mini jack
  • 5,095 posts
Posted 30 November 2009 - 09:51 PM
You told me your using 0% of the old subframe! :(
#454 HARBER07
HARBER07
  • 4,498 posts
Posted 30 November 2009 - 09:52 PM
Yeah - yesterday :(
#455 sweetser
sweetser
  • 3,995 posts
Posted 02 December 2009 - 09:53 PM
Looking good tom :tumble:
#456 HARBER07
HARBER07
  • 4,498 posts
Posted 05 December 2009 - 07:41 PM
Had a bit of a winter re-vamp today. Chucked the carpets back in, drained the rad and put anti-freeze in, fixed the electrical problems and welded the check-strap bracket on the door frame. Also got fed-up of the SC drops , so took them out and swapped for the standard A+ Helical gears. Much quieter now :). Had to make a tool to lock the gears to undo the primary shaft nut though but didnt get any pictures. Will get some tomorrow.
Dunno whether to flog the drops or not yet.
#457 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
Posted 05 December 2009 - 07:51 PM
Doubt that Mike :). Still got a Minus to sell at some point!!
Yeah, will definitely be braced down to the frame with a big bit of box section cut at an angle. - Just wanted to show then general idea.
Fixed that for ya Tom, I knew that was what you meant. :P
#458 HARBER07
HARBER07
  • 4,498 posts
Posted 05 December 2009 - 07:54 PM
You're just jealous 'because it doesn't need welding :)
#459 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 06 December 2009 - 12:55 PM
Are your straight cut drops the 998 ones? If so PM me if your interested in selling :xxx:
#460 HARBER07
HARBER07
  • 4,498 posts
Posted 06 December 2009 - 05:22 PM
Yup - real 998 ones. Will probably sell at the right price.
#461 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 06 December 2009 - 09:16 PM
cool, my friend id building a supercharged 1030, and he is after some. I'll let him know. Are they in good condition? how much are you looking for please?
#462 HARBER07
HARBER07
  • 4,498 posts
Posted 06 December 2009 - 09:26 PM
Done about 4000 miles since new. Were custom made (from a mini shop i can't remember the name of. NOT MINISPORT! :lol:) Well i paid £210 for them, so offers really.
#463 HARBER07
HARBER07
  • 4,498 posts
Posted 07 December 2009 - 07:09 PM
Well my car well and truly shat itself today. Driving to work as usual - *sniff* *sniff* "what's that?" *looks at oil gauge* "OH F*CK!!!!!" Yes thats right it read ZERO! killed the power, slammed my anchors on and pulled over. The cyclist i had just overtaken found it rather amusing (unlike me!!). Check under the bonnet, but the massive puddle of oil under the car was a good give away at what had just happened. The oil pipe for the oil cooler had blown off the union and pumped several liters of oil - practically everywhere. So rang dad - got a tow back home and got picked up for work!!
Anyways, got back home and dad had filled with new oil as he was off work today. Changed the oil cooler crap to the standard metal pipe, churned it over with the plugs out and it read 70psi - good start. Put the plugs in, started first time, then ran it up to temp. No noises or clonks yet, so was looking good. Took it for a 3 mile run whilst being followed by the recovery service (AKA dad), now sits at idle at about 5psi below what it was before. Last thing i needed was a spun main just before xmas!!!
Another great start to the week ^_^
#464 Shifty
Shifty
  • 13,138 posts
  • Name: Sean
Posted 07 December 2009 - 07:13 PM
At least its not fecked!!
Its surprising just how much abuse the little A-series can take before it spits it dummy(or crank bearings) out!!
#465 HARBER07
HARBER07
  • 4,498 posts
Posted 07 December 2009 - 07:15 PM
Yup ^_^ . I must admit i was expecting the worst!!!
    Google (1)
