1989 1015cc Mini City + Redtop
1203 replies to this topic
#436 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 29 November 2009 - 06:36 PM
Solid lifters:
(hydraulic lifters on left)
Subframe:
(hacked apart with plasma cutter)
Thought I'd try this (half expecting it not to work at all)
Welds came out OK, seeing as i made no effort to clean the metal.
So here is what i ended up with:
Obviously I've still got a long way to go but its the same principal as this:
http://www.16vminicl...cs/DSCF1116.JPG
Hopefully will allow me to get the engine back far enough to get it under a standard roundnose.
#437 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 29 November 2009 - 06:56 PM
Looks good mate, iv never seen it done like that before.
What do you plan to do with the top arms?
#438 HARBER07
HARBER07
  • 4,498 posts
Posted 29 November 2009 - 07:01 PM
Top arms will be a similar design to the bottom arms. Will use a shortened bottom arm turned upside down on the opposite side with another tie rod. All adjustable. Obviously running coilovers as well.
Edited by HARBER07, 29 November 2009 - 07:13 PM.
#439 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
What did you do before you bought that plasma cutter eh??!!
Looks good there dude!!
#440 mighty mini jack
mighty mini jack
    Mighty Before a Pint
  • 5,095 posts
Posted 29 November 2009 - 07:02 PM
Thanks for texting me about the update :)
Looks pretty mad though mate, top work to be honest!
#441 HARBER07
HARBER07
  • 4,498 posts
Posted 29 November 2009 - 07:10 PM
Cheers guys. Still a LOT more work to do on the frame though. Hopefully it will be worth it.
Dunno what i would do without it shifty :dontgetit: . Did get the grinder out but only had 1 disc left :). Anyways the cutter is much more fun ;)
#442 RacingGreen
RacingGreen
  • 2,111 posts
Posted 29 November 2009 - 10:23 PM
Looks great tom. Im looking forward to seeing how you get on trying to fit it under the roundnose. I presume you'll be trying to do it without a bonnet bulge like fbm-spec's car?
#443 HARBER07
HARBER07
  • 4,498 posts
Posted 29 November 2009 - 10:31 PM
Ideally I'd like to fit it without any bulges yeah. But if i have to stick one in it won't be the end of the world - the main one is to get it under a standard length front as I'm not a fan of extended fronts or clubman fronts on an original roundnose!!
#444 Mini-Mad-Craig
Posted 30 November 2009 - 10:38 AM
Sounds good Tom. LOL
#445 HARBER07
HARBER07
  • 4,498 posts
Posted 30 November 2009 - 05:36 PM
????? :kiss:
#446 HARBER07
HARBER07
  • 4,498 posts
Posted 30 November 2009 - 08:12 PM
Been in the garage today - Mainly as Jack wanted to see how i was gonna bolt the towers to the body. Basically it goes something like this:
#447 RacingGreen
RacingGreen
  • 2,111 posts
Posted 30 November 2009 - 08:17 PM
Looks like your progress is faster than mine. You'll be finished before me at this rate. :(
Are you planning on bracing the top mount down to the frame in some way?
#448 HARBER07
HARBER07
  • 4,498 posts
Posted 30 November 2009 - 08:22 PM
Doubt that Mike :(. Still got a Minus to rebuild at some point!!
Yeah, will definitely be braced down to the frame with a big bit of box section cut at an angle. - Just wanted to show then general idea.
#449 mighty mini jack
mighty mini jack
  • 5,095 posts
Posted 30 November 2009 - 09:00 PM
Exactly how i thought it was going to be done!
Nice work Tom! :(
#450 HARBER07
HARBER07
  • 4,498 posts
Posted 30 November 2009 - 09:11 PM
Cheers man :(
