1989 1015cc Mini City + Redtop
1203 replies to this topic
#316 sweetser
sweetser
  • 3,995 posts
Posted 05 September 2009 - 02:13 PM
changing into 3rd about 45mph, now its more like 35mph change really.
Pfftttt ALWAYS take it to 60 in second lmao i love my mini >_< haha
#317 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 05 September 2009 - 02:15 PM
Remember your gauge will be wrong because 10"ers luke >_<
#318 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 05 September 2009 - 02:21 PM
Cheers for that
I'm stuck between a 3.1 and 3.44, will probably stick with the 3.44 though.
#319 sweetser
sweetser
  • 3,995 posts
Posted 05 September 2009 - 02:54 PM
Remember your gauge will be wrong because 10"ers luke :)
My gauge is actually pretty accurate thank you very much >_<
#320 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 06 September 2009 - 11:21 AM
Yeah its got a 3.44 FDR in it. I would say its livable with, but then ive got SC drops and a weber and its not as bad as them!. Acceleration is hard to compare as its a completely different engine now, but it seems to change gear at the right times (if that makes sense). Personally i did prefer the 3.1, as i got into the habit of changing into 3rd about 45mph, now its more like 35mph change really. Still a nice drive ratio though. Sits at 70ish around 4krpm on the gauge, although thats pretty useless information as i know the rev counter is reading high :)
Im having the lump out soon, so might try a 3.76 ratio seeing as this one revs a bit more.
This worries me with my choice of a 3.6FD, probably going to have just forget about 1st gear all togther!
#321 HARBER07
HARBER07
  • 4,498 posts
Posted 06 September 2009 - 06:17 PM
Well at your spec it should rev like a goodun, so it shouldn't run out of speed :D. Its just a case of whether you can put of with the noise really.
#322 liirge
liirge
  • 4,097 posts
Posted 06 September 2009 - 10:17 PM
Got a plan for that, gonna get rally Headsets!!!
just wondering, how long do you reckon our modded smallbores are going to last until a rebuild is required?
#323 HARBER07
HARBER07
  • 4,498 posts
Posted 08 September 2009 - 06:25 PM
Well they way i drive mine, this time next week!! Had her up to 7.5K last week sometime.... on a standard crank :). Got a spare one here, so might send that to MED to get the treatment.
Anyways, the boss gave me a couple days off, and got my new trolley jack from Machine Mart today, so got the car up in the air and trial fitted the sump guard. Took the car off the ramps and it sits just under 60mm high from the road :). Hope Mini-tastic reply to my email sometime soon!. Guard came off as i dont have the Minispares order arrive till tomorrow, which doesnt include the oil hose as they are out of stock.
Also been busy doing something else, but thats a surprise till tomorrow :)
#324 HARBER07
HARBER07
  • 4,498 posts
Posted 12 September 2009 - 08:40 PM
Well yeah, not done much really. Got oil cooler fitted, and sump guard holes are drilled - will fit that tomorrow. Managed to shear the oil hose end screwing it into the filter housing though :) so had to chop the original threaded adaptor and weld that to what was left of the new union.
Also got a new thick-walled rocker shaft as my one was well passed it. Got fed up of skinning my knuckles on things adjusting the tappets from last time, so made this little beauty:
Just an 11mm socket welded to a piece of tube and a BIG nail welded to that to make a handle. Obviously the idea was to raise the turning handle so i cant skin my knuckles, and still leaves a hole down the middle for a flat head screwdriver. So changed the shaft today and now sounds much less tappetty.
Edited by HARBER07, 12 September 2009 - 08:41 PM.
#325 mighty mini jack
mighty mini jack
    Mighty Before a Pint
  • 5,095 posts
Posted 12 September 2009 - 08:57 PM
Looks well good man, might buy one off you soon!
( i think you need more pendulum on to be honest!) :)
#326 HARBER07
HARBER07
  • 4,498 posts
Posted 12 September 2009 - 09:00 PM
Thats why i didnt get much done to be honest - was raving it out the front of the house :)
Might re-fit my zorst tomorrow if i can be bothered.
#327 HARBER07
HARBER07
  • 4,498 posts
Posted 16 September 2009 - 09:55 PM
This will no longer be a small bore in 12 months :thumbsup:
Going to collect a C20XE i just won on eBay, at the weekend. Comes with all the carp - F20 'box, ECU, wiring loom, driveshafts, manifold, ancillaries etc.
Bit of a bargain, and only 60 miles away.
#328 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 16 September 2009 - 10:01 PM
This will no longer be a small bore in 12 months :shifty:
How much did you pay for it?
Are you going for an extended or slab front?
What will be fueling it?
Throttle bodies I hope.
#329 HARBER07
HARBER07
  • 4,498 posts
Posted 16 September 2009 - 10:05 PM
Too right! R1 ITB's, and megajolt for ignition.
As for fronts, whatever fits. Not keen on the extended's so probably clubby front.
And i dont want to say how much I paid till its in my hands :shifty:
#330 sweetser
sweetser
  • 3,995 posts
Posted 16 September 2009 - 10:32 PM
I know how much lol
