Guide To "tubbing" Rear Arches
20 replies to this topic
#16 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 06 February 2011 - 01:11 PM
i guessing mini_turbo_pete deleted them from his photobucket account
try a PM to him to see if he still has the pictures
#17 camp freddy
camp freddy
  • 3,696 posts
Posted 10 February 2011 - 10:03 PM
if you look through my thread you can see the process.
#18 vini
vini
  • 316 posts
  • Local Club: no never again
Posted 11 February 2011 - 08:57 AM
any idea what pages,theres 160 there lol :shifty: Dean
#19 camp freddy
camp freddy
  • 3,696 posts
Posted 11 February 2011 - 09:01 PM
any idea what pages,theres 160 there lol :thumbsup: Dean
I know just a few....
#20 camp freddy
camp freddy
  • 3,696 posts
Posted 11 February 2011 - 09:03 PM
mark round the center of the inner arch and cut out, I used an angle grinder with a
cutting disc ( the thin type)
cut round the outer lip and remove the unwanted arch section, use a rule and place
it across the arch and touching the body mark where it touches and form an arc, measure
down from this line about 20mm and make another arch , then trim any metal below this
line, now cut back up to the first line to make tabs as in the above pic or you could make
a template , get some hard card the same size as the arch opening , put it against the arch
mark where it meets the floor and aound where it touches the arch, cut the arch out. place
the template on the outer panel line up with the floor then mark out, remove and mark down
about 20mm make another arch and continue as other option.
then fold up the tabs, trim so they are about 10mm wide
get a piece of thin sheet and bend it using your knee, weld this to the remaining inner arch
I then welded round the edge of the arch, then had to weld the fold slits
then clean up the welds and use a good primer
there you are, any more give me a message
Edited by camp freddy, 11 February 2011 - 09:55 PM.
#21 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,146 posts
  • Name: Sean
Posted 11 February 2011 - 09:13 PM
Carl, if any of your pics match Petes description post em up and I'll add them to the text.
