thanx
nick
Posted 10 March 2008 - 11:22 PM
Posted 11 March 2008 - 12:38 AM
Posted 11 March 2008 - 10:23 PM
Posted 11 March 2008 - 10:33 PM
Posted 14 March 2008 - 07:35 PM
Posted 16 March 2008 - 04:21 PM
The 2.2 is a lot heavier and not that much more powerful than 1.6VTi lump. Smaller engine spool up faster than bigger ones, as the 1.8 ford Zetec engine compared with the 2.0L version.
I'd fit the 1.6 ESi engine and turbo it!!
Posted 22 March 2008 - 12:35 PM
Posted 25 March 2008 - 07:15 PM
THE 2.2 PRELUDE LUMP IS HUGE AND HEAVY NOT EXTREMLY POWERFUL, WHY WOULD U WANT TO PUT ONE IN A MINI. THE 1.6 IS A FAR BETTER LUMP U CAN GET 200 BHP FROM ONE NO PROBS. FORGET THE TURBO THERE QUICK ENOUGH WITHOUT. ITS BEEN DONE TRYED AND TESTED.
KEEP IT UP FRONT THEY HANDLE BETTER.
Posted 11 June 2008 - 10:59 PM
Posted 12 June 2008 - 01:13 AM
Posted 12 June 2008 - 05:08 PM
Edited by Kam, 13 June 2008 - 08:43 AM.
Posted 26 June 2008 - 01:05 PM
TRU DAT!!
Posted 26 June 2008 - 09:41 PM
Posted 26 June 2008 - 09:47 PM
Edited by The Pogg, 26 June 2008 - 09:52 PM.
Posted 28 June 2008 - 09:52 PM
Hmm..
2.2 v-tec is only 75kg heavier, tis an alu block.
Creates 197bhp as standard form in a JDM, engine will cost you about £300 with 100k on the clock.
Whack on a Fidanza 8lb flywheel and it'll spin up fast enough.
Plenty of modifications available for the 2.2, being able to tune the cars N/A to crazy power. More then you'd be able to put to the floor.
In the prelude, the 2.2 with 250hp struggles to keep the tyres to the floor.. so in a car half the weight, you'll have real problems.
Other issue you're really going to face is hitting the floor with it. When you do a conversion into a CRX you have problems with hitting the sump, so in the mini it'll be dragging along the floor.
That said, i wish i had the knowledge to be able to do this.. You'd seriously have to alter the mini loads, and probably make it 4wd to keep the power down.
So, cost wise, 1.6 will be your best bet.
Anywho.. thought i'd add my 2p
