Quick Price Check (rolling Road).
#16
Posted 10 March 2008 - 12:40 PM
In reply to the first qu, I'd say £80 was fair. Who you taking it to?
#17
Posted 10 March 2008 - 12:44 PM
yes but my engine has been mucked about with and im running a 2 and 3/4 inch stainless pipe and cone filter. also an auto so the rev range has to be spot on for the kickdown. not s easy as 'bung a needle' in there.5 needles :S southam got everyone bang on first time i believe, just SU's, just 1 needle, 1 profile, based on engine spec. Rolling road only makes it easier and a tiny bit more accurate so that other 0.0000001bhp can be achieved.
and you can check timing on rolling road under load... but with timing it makes no difference if its under load or not, strictly on rpm.
#18
Posted 10 March 2008 - 12:48 PM
Rather have a car that has been given the professional once over at least one time. My car now runs great and very economically. im very pleased and would have spent much more to get it running like it is now.
#19
Posted 10 March 2008 - 12:52 PM
#20
Posted 10 March 2008 - 01:02 PM
I have no idea. i can tell you alot about hooveringcant say anything back to that! lol, aint fondled with automatics before. Just wrote a 5000 word + writeup on automatic transmissions with manual overrides, i no how automatic boxes work! but no experience. What is the hydraulic fluid to the band valves and piston valves relative to though?
#21
just standard 1275's and 998's with stage 1 kits on em. Which do not need rolling road sessions.
Apart from being quite wrong about Stage 1 kits Alex (which do need to see the rollers, any kit vendor or tuner will tell you that) perhaps you would like to read my first post that you took such exception to again and a little more closely, you might find I already said exactly that. Cars don't just go on the rollers for a tune, they need to go on the rollers with a Stage 1 to get checked out. Whenever the tune is non standard you need to assess the entire rev range under load to make sure you aren't going to destroy the engine in a couple of thousand miles. Doing that on the rollers is easier than on a test drive. And the advance of a dizzy ignition is load dependant, that's what the vacuum unit governs. Not wanting to contradict Jammy here but it was because MLM did my car without the rollers that I was impressed. Not because I was impressed by the needle choice or profiling, I am fully aware that if you have a lot of experience then all you need to set up an SU is a good ear (and not a Colortune, it's pretty hard to keep your eye on the end of it on the back roads) which is how my dad does them. I was impressed by how accurate they were at adjusting the dizzy advance without a scope. They are amazing technicians but only because of the experience they have and the care they take. Professionalism means checking what you've done, not just assuming it's OK.
Edited by Dan, 10 March 2008 - 01:04 PM.
#22
Posted 10 March 2008 - 01:05 PM
your lucky im a married woman .....just standard 1275's and 998's with stage 1 kits on em. Which do not need rolling road sessions.
Apart from being quite wrong about Stage 1 kits Alex (which do need to see the rollers, any kit vendor or tuner will tell you that) perhaps you would like to read my first post that you took such exception to again and a little more closely, you might find I already said exactly that. Cars don't just go on the rollers for a tune, they need to go on the rollers with a Stage 1 to get checked out. Whenever the tune is non standard you need to assess the entire rev range under load to make sure you aren't going to destroy the engine in a couple of thousand miles. Doing that on the rollers is easier than on a test drive. And the advance of a dizzy ignition is load dependant, that's what the vacuum unit governs. Not wanting to contradict Jammy here but it was because MLM did my car without the rollers that I was impressed. Not because I was impressed by the needle choice or profiling, I am fully aware that if you have a lot of experience then all you need to set up an SU is a good ear (and not a Colortune) which is how my dad does them. I was impressed by how accurate they were at adjusting the dizzy advance without a scope. They are amazing technicians but only because of the experience they have and the care they take. Professionalism means checking what you've done, not just assuming it's OK.
#23
Posted 10 March 2008 - 01:12 PM
and as for all bases of your engine being covered, did they check your bottom end on the dyno? no. Cam wear? no. They dont even take the rover cover off and check clearances in most places. All bases aint checked on a rolling road, just fueling and timing, it can also draw attention to oil burning problems which can be linked to mechanical defaults.
Edited by alexcrosse, 10 March 2008 - 01:14 PM.
