Cutting Compound
Posted 05 March 2008 - 05:33 PM
What type(s) of cutting compound should I use?
Where can I get it from - Halfords only seem to sell T-Cut type stuff.
Any advice appreciated.
Posted 05 March 2008 - 06:17 PM
Posted 05 March 2008 - 06:21 PM
Alot of bodyshops use it, its not the cheapest, or the dearest but is pretty good.
I think G3 would be your best bet. Do you have an electric polishing machine or will it be a elbow grease affair?
http://www.roostersa...Products/g3.jpg
Posted 06 March 2008 - 12:03 AM
Posted 06 March 2008 - 12:06 AM
Posted 06 March 2008 - 01:32 AM
Posted 06 March 2008 - 08:30 AM
I cut back and polished every bit of bodywork on our mini van by hand after we sprayed him!!!
A scuttle will be easy to do by hand, like others have said, Farecla G3, then a finer grade, and finish with a clay bar or good polish... But yes, it will be easier with a mop. Just make sure you don't go through on the edges!
Posted 06 March 2008 - 11:55 AM
The finish at the moment (with clearcoat lacquer) doesnt look good, not sure if we sprayed it wrong, it looks kind of frosty...
Posted 06 March 2008 - 12:09 PM
If it's looking frosty then it may need to be done again, how warm was it when you painted it? as basecoat paint doesn't like the cold and will go a kind of frosted colour, then when it's laquered it will look the same but shiney.
when i painted the transformers sign on my roof i flatted and polished it by hand, i used 1200, then G3 then 3m finesse. it came out lovely.
Posted 06 March 2008 - 01:10 PM
The lacquer went all frosty the moment we put it on.
I guess worst case I have to wet n dry the lacquer off and reapply.
First time paint repairs...
Posted 06 March 2008 - 01:18 PM
Base coat went on really well it was about 12 degrees outside, but we did it in a garage.
The min temp you should paint 2K paint in is about 18 degrees.
You won't be able to just wet n dry the laquers off, your best off smoothing off the top of the laquer with 800 grit and then start again.
If the laquer has gone all frosty then you have probably got something wrong with the laquer somewhere. what laquer are you using and what thinners & what hardener?
Posted 06 March 2008 - 03:01 PM
Didnt use thinners or hardener...
Edited by coopertrooper2001, 06 March 2008 - 03:01 PM.
Posted 06 March 2008 - 03:11 PM
Posted 06 March 2008 - 06:02 PM
Is it aerosol stuff you used?
I hope it is, having used no hardener!
Lol!
Posted 06 March 2008 - 07:38 PM
