Thats a question thats been answered so many times on here.
Its Not a kit you can buy as such, more of a one off I'm afraid.
Posted 21 February 2014 - 05:55 PM
Posted 14 March 2014 - 11:39 PM
function over form!
Posted 18 March 2014 - 11:57 AM
hycote wrinkle effect ,but its a pig to do , you have to follow the instructions to the last detail or it doesnt work .
Posted 19 March 2014 - 03:57 PM
I have heard the vht stuff is pretty good, there is also a guide on build threads.com guy had developed a method that seems to have worked very well.
Posted 21 March 2014 - 08:15 AM
That looks fantastic - what a great job.
My engine bay looks horrible, the sound proofing foam is what makes it look the worst, looking at all of these pictures it looks like you guys have just removed it and treated / painted the metal in the engine bay, is that correct and is that the best way to do an engine bay? Or have you replaced the sound proofing?
I'd appreciate the advice.
Posted 21 March 2014 - 02:18 PM
would it be much work to take a engine out iv got 1275
Posted 21 March 2014 - 02:23 PM
Not at all - you can get the engine out in a day easy.
Posted 21 March 2014 - 08:55 PM
Lose the sound deadening water sponge ;) It causes more rust problems than it does at deadening sound
Posted 22 March 2014 - 01:18 PM
i would say loose the sound deadening but its your choice prone to make the bulkhead rust probly other surrounding areas is well :)
Posted 23 March 2014 - 08:04 AM
Remove the sound proofing in the engine compartment and install Dynamat on the inside.
Edited by Shukran, 23 March 2014 - 08:05 AM.
Posted 23 March 2014 - 09:40 PM
Shukran - By inside do you mean in the seating area against the bulkhead?
Posted 23 March 2014 - 11:00 PM
Yes he means inside the cabin.
If you install a CLD (Dynamat etc) against the fire wall from below the upper dash rail to the floor foot well, then a layer of CCF (closed cell foam) followed by a layer of MLV (mass loaded vinyl) or similar you will reduce the noise hugely compared to the oem open cell foam sponge from the engine bay. You can even get heat reflective adhesive mat like dynamat for inside the engine bay if you want.
0 members, 7 guests, 0 anonymous users
