They'll be replaced by nice steel brackets eventually I promise.
Posted 18 May 2012 - 06:35 PM
Posted 23 May 2012 - 07:25 PM
Cheers. Cool stuff. Yeah it's been installed for just over two years now. I believe it is running around 110bhp at around 6000RPM. It's been pretty reliable though after sorting a few initial teething problems. It's fairly standard to be honest, it's a 1275cc Rover Mini Sprite. It was one of the very last carb Mini's...
The engine internals are completely standard as is the head except for some 1:5 roller tip rockers and double valve springs. It has a HIF44 carb with a little electric heater that I installed in the air filter to prevent icing. It has a Minispares 2 core radiator and a 82degree thermostat. Had to sort out an additional breather running from the rocker cover too. Otherwise it's standard. I have been tempted to change the head and cam but to be honest it goes really well so until I have any problems I think I'll just keep it as it is.
Good to hear it runs reliable, mines nearly done now, possibly this weekend. do you have any trouble starting it? i have a heater element in mine too, alough its not wired in yet.
Posted 26 May 2012 - 09:26 PM
Sorry about the late response, is yours done now? What spec and performance have you got? Not really, it usually requires a bit of choke to get going though, it's only ever a problem if it is very damp but it's kept in a garage so that isn't really a problem. Ah cool stuff, the element is a worthy addition.
Cheers,
Jon.
Posted 28 May 2012 - 08:58 AM
Posted 28 May 2012 - 07:21 PM
Ah cool stuff, well keep me posted, it'd be cool to hear how you get on. I get around 26mpg. I've worked it out on loads of occasions and that seems the standard really, I haven't managed to better that.
Cheers,
Jon.
Posted 28 May 2012 - 10:47 PM
Cheers,
Jon.
Do the suck through superchargers work ok? What do they run like?
Posted 28 May 2012 - 11:46 PM
Posted 04 June 2012 - 08:56 PM
Posted 05 June 2012 - 09:37 AM
Posted 05 June 2012 - 10:02 AM
Posted 05 June 2012 - 12:47 PM
I'm inThis is the finished kit.
If there is enough interest I will make an inlet and have a limited run of copies made for people who want them.
I'm not looking to proffit so all costs would be shared by each unit 9more ordered the cheaper they will be)
Let me know guys![]()
Posted 06 June 2012 - 08:13 PM
A couple that I have done
Posted 06 June 2012 - 08:24 PM
Posted 07 June 2012 - 07:16 PM
where can i get that induction box etc?
Posted 09 June 2012 - 10:10 PM
