Engine Bay Styling!
848 replies to this topic
#271 cooperS
cooperS
  • 116 posts
  • Local Club: MOC Santiago, Chile
Posted 26 April 2011 - 01:58 AM
my new engine bay, no more A series, now turbo 16V lump inside! :thumbsup:
#272 mercian131
mercian131
    Just On Tickover
  • 8 posts
Posted 26 April 2011 - 01:46 PM
there are some beautiful smart bays on here, first on my wishlist is to tidy it up.
but how much of it is down to tidying a standard bay and how much relies on just buying flashy parts?
Cheers, Harrison
#273 mad mk1
mad mk1
  • 746 posts
  • Local Club: TurboMinis.co.uk
Posted 26 April 2011 - 06:21 PM
My new Turbo Eng bay 95% done.
#274 minikev84
minikev84
  • 200 posts
  • Local Club: TVMC
Posted 26 April 2011 - 07:27 PM
Sweet, would anyone happen to know if the halfords aerosol degreaser is any good ?
GUNK is not as good as it use to be bk before it had to be friendly so its all much the same now. I cover up the electrics and gave it a quick pressure wash and it had no problems starting and looked very clean.
I considered that, mates got a pressure washer, how did you cover up the electrics and how careful were you ?
I did it and had no problem I'm NOT telling you to do it I don't want you to do and have problems, its up to you. I used some shopping bags and bands on the dizzy and coil then used a air line to dry it of before i started the engine and ran it till it got warm.
#275 mad mk1
mad mk1
  • 746 posts
Posted 26 April 2011 - 07:40 PM
when i do it, i get the eng hot and then keep it running as i wash it.
this is just one more way to skin the cat.
#276 connor_cooper
connor_cooper
  • 164 posts
  • Local Club: no
Posted 13 May 2011 - 09:54 AM
Attached File  IMG_0514.JPG   2.54MB   71 downloads
My new engine just after i dropped her in :thumbsup:
#277 mini-mayhem1991
mini-mayhem1991
  • 16 posts
Posted 18 May 2011 - 04:26 PM
A couple that I have done :shifty:
was just wounder in how have you got a carb and a masive air filter like that looks nice blue :genius: whats thta thing called that on the carb sorry if sounds daft :L
#278 garrett3
garrett3
  • 1,412 posts
Posted 21 May 2011 - 03:28 PM
was just wounder in how have you got a carb and a masive air filter like that looks nice blue :thumbsup: whats thta thing called that on the carb sorry if sounds daft :L
Hi,
The filter is just a cheapie ebay jobbie for around a tenner, the chrome pipe is actually just a polished alloy boost pipe from the bay at about £5.
The boost pipe connector was about £4 and the jubilee clips were pence from Wico's.
The inlet section attached to the carb is an air intake from another austin that has been cut and re welded (alloy tig) back together in the angles and position needed to make the kit work.
The inlet was an ebay jobbie and cost £15. and then another £20 to have welded once I had everything where I wanted it.
I was asked to make a run of kits but did not get enough people to make the kit cost effective.
The inlet would have been made out of fibreglass or similar and in limited numbers the kit would have cost £90 without a penny of proffit.
I would have needed 100 poeple to get the cost down to around £60+post with no proffit.
I did paint the inlet to show how it would look in fibreglass.
#279 mini-mayhem1991
mini-mayhem1991
  • 16 posts
Posted 21 May 2011 - 04:25 PM
thats sicks that i would love to have go at that where can i get the inlet from that on the carb whats the name of it called thanks nick i did message you
Hi,
#280 minilee94
minilee94
  • 3,523 posts
Posted 25 May 2011 - 03:14 PM
new update of mine :D
#281 karl minigt
karl minigt
    Starting My Mini Up
  • 2 posts
Posted 25 May 2011 - 03:54 PM
Attached File  engine.JPG   1018.65K   48 downloads
#282 M44K TS
M44K TS
  • 3,104 posts
Posted 25 May 2011 - 05:15 PM
Lee - black engine FTW!
#283 minilee94
minilee94
  • 3,523 posts
Posted 25 May 2011 - 05:46 PM
hahah yhh i love the black engines looks smart
#284 Hughes
Hughes
  • 377 posts
Posted 25 May 2011 - 10:01 PM
Just finished re doing mine. Host of new parts this time too. Also disassembled the brake servo and its bracket and repainted it. Repainted loads of other bits too but this time with plenty of lovely lacquer - which was the vital part I left out last time.
New bits:
Clutch master cylinder, slave cylinder, clevis pin and braided hose
Smiffys bits various
Earth strap
Poly steady bushes
New Rocker Cap
Various gaskets
Spent a small fortune on primers, black paint and lacquer!
Oh and a pic of my gorgeous MED LD Roller Rockers :withstupid:
#285 M44K TS
M44K TS
  • 3,104 posts
Posted 25 May 2011 - 10:19 PM
That's very tidy, good work dude, I particularly like the neatness of the fusebox wiring.
