My '92 SPi always ran cold, ever since owning it. The previous owner said, "It's always been like that." Well, this winter, sick of freezing in my car, I decided to replace the thermostat.
That simple job took MUCH longer than expected. Seems that the original thermostat was still in the housing. The bolts had never been removed, so one was rusted to the housing. (Not the engine block, thanks!) So, I went ahead and ordered a new housing and sandwich plate for the heater hose, new thermostat, gaskets and bolts. The old thermostat was in fact stuck partially open, so it was tossed.
Got all the parts in, reassembled everything. First oddity was that the bolts were too long - each one needed two or three additional washers to tighten down correctly. I thought I got the right bolts (These are the ones I ordered) but am wondering if I err'd. I'd lioke to get the correct ones, if anyone knows the correct part #, it'd be appreciated.
Anyways, back to the cooling. While the fluid was low, I looked in the radiator, and do know that it needs a flush, badly. However, it did not get one at this time. I'm glad I didn't - the engine STILL runs cold. (Yes, I checked the thermostat before putting it in - it was good.
I'm thinking I need a new temp sender - anyone have a picture of where it's located? Any other items to check would be appreciated as well. I don't like freezing in the mornings.
Cheers,
Mike.
