What Thermostat
27 replies to this topic
#16 [email protected]
[email protected]
    Minispares
  • Minispares
  • 3,229 posts
  • Name: Simon Jackson
Posted 17 February 2008 - 08:58 PM
Miglia's are really another kettle of fish, high spec engines, run for much smaller periods of time, with usually much more modification in regard to cooling.
I wouldn't advise anyone not to run with one on a road car, without fitting a blanking sleeve
#17 Spenner
Spenner
  • 890 posts
  • Local Club: Blakehill mini's
Posted 17 February 2008 - 09:06 PM
Ive got alarm bells ringing i been running mine with out a thermo for ayear and had it getting really hot at high rev's :P hope i havent done damage.
#18 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 26 February 2008 - 03:01 AM
so i pulled the stat and it is a 180 deg F which works out as an 82. the spare i have is a 91 deg C.
which one should i put in?
#19 coyttl
coyttl
  • 243 posts
Posted 26 February 2008 - 03:41 AM
Sprocket! Waitaminute... What temp is SUPPOSED to be in an SPi or MPi? I posted a thread about my engine never warming up, and I replaced the stuck-open thermostat with a 71C/160F one!
Miniboo - another source told me that the 71C one was 'standard' for Mini's. However, I don't know how accurate that is now..
#20 miniboo
miniboo
  • 9,327 posts
Posted 26 February 2008 - 05:10 AM
no i think 71 is way too cold to be honest 88 is standard according to Haynes.
pre 1976:
standard=82
hot climates=74
cold climates=88
post 1976:
Standard=88
#21 Aria Aradhea
Aria Aradhea
  • 563 posts
  • Local Club: Jakarta Morris Club
Posted 26 February 2008 - 11:35 AM
I use the 74deg. thermostat because of the hot climate over here. I have a question, though, is it true that you have to drill holes in the thermo if you're using the waterpump/head without bypass hose? Or is it okay to fit the thermo as it is? Thanks, and sorry to hijack your thread, miniboo...
#22 coyttl
coyttl
  • 243 posts
Posted 26 February 2008 - 03:13 PM
Someone may correct me if I'm wrong - but I believe that you DO need to drill small holes. Otherwise, the thermostat won't ever warm up properly (on the back-side, the side with the spring) and never open.
Thanks for the info on the temps. That could be why I'm never getting a hot engine. :thumbsup: Luckily I have a 80C/180F backup at home, I'll slip that in tonight. :ph34r:
#23 BJst416
BJst416
  • 338 posts
  • Local Club: Racer's Porn Shop
Posted 26 February 2008 - 04:40 PM
I use an 88 deg 'stat in sunny Venezuela.
Although with some variables in the cooling system:
- 88 stat with 6 1/8" holes around. [Can't get mini parts here but a stat from a blazer 96-99 (54mm diameter) does the trick]
- Got rid of the by-pass hose.
- Since i don't run a heater, run a pipe from the heater take off to the top hose or in my case to the spacer plate between the head and the stat housing. (old plan pic below, will add new one soon)
- Added aux fan with thermo-switch @ 92 on and 86 off.
Even in the hot days, and believe me it gets hot here, it will sit about 1mm below the middle line in the temp gauge.
So I'd say yeah, 88 degrees is the way to go.
EDIT: mine is a 93 carb Mini Cord
EDIT: the spacer came standard in minis with A/C however i'm sure the so called "sandwich plate" that minispares sales will be fine, or you could fabricate one.
Edited by BJst416, 26 February 2008 - 05:45 PM.
#24 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 26 February 2008 - 09:21 PM
The Injection engines need the 88 stat otherwise the ECU will keep the engine running in cold start, and run rich all the time.
#25 coyttl
coyttl
  • 243 posts
Posted 26 February 2008 - 10:33 PM
Well, d'oh. Thanks for that. I hope my oxygen sensor isn't toast now, with it running cold not only through MY ownership, but the previous owner's.. Ouch.
#26 Arfur Lager
Arfur Lager
    Just On Tickover
  • 8 posts
Posted 26 February 2008 - 10:44 PM
whilst on the subject my fan wouldnt go off at all this morning,the car had only been running 5 mins.
guess my thermostats dicky ? any help gratefully recieved !
#27 miniboo
miniboo
  • 9,327 posts
Posted 27 February 2008 - 01:50 AM
erm which fan? if it is the one to the left of the rad then it is always on as it is driven by the engine. if ti is a leccy one on the inner wing then yeah you may have a dodgy switch for it. this does NOTY mean the thermostat in the head is dodgy. if it is a newer mini then it will be the thermostatic switch at the bottom of the radiator. it normally kicks in at about 91 deg c i think(might be 94) so it should vary rarley be on.
#28 Arfur Lager
Arfur Lager
    Just On Tickover
  • 8 posts
Posted 28 February 2008 - 05:30 PM
sorry,yes i meant the electric one.my mini is a 1997 so i guess thats a newer one ,cheers for your advice
