Minisport Camshafts
Posted 10 April 2005 - 06:35 PM
I'm thinking of buying the CA6 MK3 'Rally' Kit
The info given is the following
Power Band : 2800-7500
Valve Timing : 34-74 / 75-45
Unofortunately no duration is given, can this be calculated from the Valve timing figures?
Cheers, Makis
Posted 10 April 2005 - 06:43 PM
go for something like the Swiftune range of cams, they've been race proven, keith calver (mini-god) uses them for his engines, Morspeed ones are good also
as for valve timing, im sure someone like Dan or siggy will have a good idea
are you going to rally the car then? or is it just a cam equivalent to the engine spec?
Posted 10 April 2005 - 07:00 PM
Posted 10 April 2005 - 07:11 PM
Posted 10 April 2005 - 07:38 PM
Posted 10 April 2005 - 10:04 PM
in my experience everything has to be matched to achieve the best performance gains
you wouldnt stick a 45 weber on a standard 1275 now would you
my current engine is fast road spec and an SW5 (or equivalent) is absolutely perfect
Posted 13 April 2005 - 01:43 PM
Posted 13 April 2005 - 04:53 PM
Posted 13 April 2005 - 06:32 PM
Posted 13 April 2005 - 06:50 PM
Posted 14 April 2005 - 11:50 AM
The cam is rated for 8000rpm, will 200lb springs be sufficient?
Posted 14 April 2005 - 03:07 PM
Posted 14 April 2005 - 03:26 PM
286 it is then
i start to believe that it's gonna take ages to decide on the parts, nevermind to fit them, lol
Posted 14 April 2005 - 04:30 PM
Posted 14 April 2005 - 05:06 PM
same size valves as an mg metro...bargain
huh?!?!?!
i'm off to the scrappie
