1275gt Restoration
#226
Posted 18 September 2008 - 11:11 AM
If all good clean and paint.(more than likely if it has covered 40k of nn thrashed driving)
Rebuild head, re lap/cut in valves (consider unleaded conversion? depends on how much mileage you will be doing? I have never bothered and use an additive pesonally) Fit new valve stem seals/gaskets etc.
Refit gearbox when returned, fit a new clutch and paint/ polish as required.
#227
Posted 18 September 2008 - 11:15 AM
xx
#228
Posted 18 September 2008 - 12:01 PM
Do a compression test, if you haven't already, and take it from there. Rebuilding the head will allow you to get a better idea of the condition and allow for some simple improvements if you fancy a bit of a tinker.
#229
Posted 18 September 2008 - 12:46 PM
#230
Posted 18 September 2008 - 12:52 PM
I reckon just clean yer engine up until it's looking OK. As Eff's said, maybe do a compression test, but if there aren't any obvious problems then I'd just use it as it is to be honest. No point stripping an engine down when there's nowt wrong with it I say.
#231
Posted 18 September 2008 - 12:56 PM
That's exactly what I wanted to hear. You say good things to lazy ladies like me.
#232
Posted 18 September 2008 - 12:59 PM
Just give it a scrub down and a nice lick of paint
Love the project, hope you get the finish you after, after putting in all the hard work
#233
Posted 18 September 2008 - 01:10 PM
Maybe consider changing the valve stem seals as it has not been usd for a while as they do deteriate and age harden.
#234
Posted 18 September 2008 - 01:42 PM
#235
Posted 18 September 2008 - 01:47 PM
#236
Posted 18 September 2008 - 03:13 PM
Ficko
XX
#237
Posted 18 September 2008 - 03:20 PM
To change them you would need to remove the head and remove the valve springs but this could all be part of the head de-coke rebuild. This would only cost a head gasket set which is about a tenner.
I could do it for you if you can get the head to me?
#238
Posted 18 September 2008 - 03:22 PM
#239
Posted 18 September 2008 - 03:32 PM
thanks for the offer, mk3 Cooper S, but I reckon I could do it myself*.
*says she knowing full well she hasn't got a clue what she's talking about but will spend the next few weeks reading up on it.
#240
Posted 18 September 2008 - 03:48 PM
In terms of tools you will need:
Valve spring compressor
Valve lapping tool and lapping paste
Valve seat cutter (only if the valve seats are badly pitted)
#1 rule - Always make sure that the removed valve returns to the same valve guide or location.
Give me a shout if you have any questions
