sweet!
Wish mine was thus nice.
Fankoo.He's going to look far worse before he gets better, though....
Yep. Mine looked Ok when I got it.... then I poked him a little bit... then most of him was on the floor
He's getting there though....
Posted 11 May 2008 - 08:27 PM
sweet!
Posted 12 May 2008 - 07:43 AM
He's looking all naked!!! I'm really enjoying seeing this project come along
The bumper bolts might fre with some 'freeze & release' spray from Halfords or motor factors.
Although it didn't help me! I had a similar problem with my clubby bumpers - the previous owner had forced metric bolts in and there was no way they would shift - they just twisted the brackets. I ended up getting the bolts wound out a little until I could get a hacksaw blade between bumper and car and then cut the bolt. However as you are respraying I would simply grind the head off the bolt from under the wing then tackle the remains once the bumper was off the car (you might find then that the heat from grinding will have freed the threads).
Posted 13 May 2008 - 07:28 AM
Posted 16 May 2008 - 01:15 PM
Posted 16 May 2008 - 01:28 PM
a small hand job
Posted 16 May 2008 - 02:00 PM
a small hand job
aye up!
Posted 16 May 2008 - 02:28 PM
Posted 16 May 2008 - 02:33 PM
Think i would, around the fresh air vents is a fave rot spot. just removing the dash cards 'n clocks should do it. Also gives you the chance to prettify or replace the cards there almost guaranteed to be a bit dog eared.
Posted 16 May 2008 - 02:42 PM
Posted 16 May 2008 - 02:43 PM
Posted 16 May 2008 - 02:54 PM
Posted 16 May 2008 - 04:05 PM
Posted 17 May 2008 - 03:18 PM
love the ram bar juju
Edited by Juju, 17 May 2008 - 03:21 PM.
Posted 17 May 2008 - 03:33 PM
Mine was all rusty at the end of the bottom dash rail wher it is welsed up next to the A pillar. It's a common area on clubbys, so definatly worth a look. Also worth checking where teh door check straps poke through and around the inside of the fresh air vents.
Better to take it of now and have a look than for it all to drop of from rot when you get it back on the road.
Posted 17 May 2008 - 03:45 PM
I've found little chunks of sponge wedged up the screen pillars around there, god knows what BL intended them to do, but they're very effective at spawning rust patches![]()
