Cooling System Direction Of Flow.
Posted 12 February 2008 - 03:05 AM
has anyone got a good diagram with arrows on or the like?
Posted 12 February 2008 - 10:15 AM
Pump pushes water into the block
Water comes out of the top hose and water comes out of the heater take off
Water goes down the radiator and water goes through the heater matrix
Water goes through the bottom hose
Back into the pump
And round and round and round and round etc...
That way the engine is using the *cooler* water from the bottom of the radiator...
Edited by langers2k, 12 February 2008 - 10:16 AM.
Posted 12 February 2008 - 12:24 PM
Water pump pumps water out through thermostat housing and into top of rad where it sinks as it cools and back in through bottom hose.
Posted 12 February 2008 - 12:34 PM
throught the thermostat housing into the rad
into the top hose
out the bottom house
through the water pump and back into the engine.
Posted 12 February 2008 - 12:35 PM
Posted 12 February 2008 - 04:01 PM
Posted 12 February 2008 - 04:32 PM
ok what about the Bypass then on an older engine? does it go into the head or out of the head?
Out of the head into the pump I think.
Means if you have the heater off, and the engine is cold the water is only circulating the engine until it warms up. Once it warms up the thermostat opens and it starts circulating the radiator the bypass is redundant.
Later engines don't have them, or at least mine doesn't so if the head you are fitting doesn't have a bypass connection, just get a water pump without one and it will be fine.
Posted 12 February 2008 - 04:43 PM
i just couldnt remember if teh bypass let water out oif the head or into the head. Out of th ehead is great for what i want to do.(bmw K100 Head by the way)
Posted 12 February 2008 - 04:51 PM
out the cylinder head
into the top hose
The heater just relies on hot water rising out of the head and flowing into heater via heater valve, the cooled water then drops back into the system at the top of the bottom hose.
Later engines have a relief hole in the thermostat instead of a bypass hose.
Edited by minimender, 12 February 2008 - 04:51 PM.
Posted 12 February 2008 - 04:52 PM
Posted 12 February 2008 - 06:36 PM
Posted 17 February 2008 - 11:42 AM
