Jack Knight Drop Gears..
13 replies to this topic
#1 andydlc
andydlc
  • 77 posts
  • Local Club: JMC&LCC
Posted 11 February 2008 - 05:48 PM
Hi All,
What is the difference between Jack Knight Transfer gear sets and Transfer roller kits?? Is there a marked improvement in the roller kits and is it worth forking out the extra cash??
Thanks in advance..
Andy
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 12 February 2008 - 07:43 AM
the roller kits use a tapered bearing which reduces the side load on the soft aluminum cases even further than a std set of SC drops... The is a benefit in cars which are pushed hard, eg competition etc etc
Also don't limit yourself to JKD
#3 mini_mission
mini_mission
  • 442 posts
  • Local Club: bumpstart
Posted 12 February 2008 - 12:31 PM
guessworks, out of interest, can you explain- i thought the whole idea of s/c drops was to reduce to side load anyway? would it not be an unjustifiable expense?
#4 andydlc
andydlc
  • 77 posts
Posted 12 February 2008 - 12:38 PM
Guessworks, not wishing to sound naive but what other manufacturers do I have as options for a set of SC drop gears? :thumbsup:
#5 [email protected]
[email protected]
    Minispares
  • Minispares
  • 3,208 posts
  • Name: Simon Jackson
Posted 12 February 2008 - 02:03 PM
We have our own range, please see the below article on our site, it will also give you links to the gears we have available
http://www.minispare...le.aspx?aid=109
#6 andydlc
andydlc
  • 77 posts
Posted 12 February 2008 - 03:31 PM
good article!! :thumbsup:
#7 andydlc
andydlc
  • 77 posts
Posted 13 February 2008 - 11:53 AM
Simon@minispares - Am I right in thinking you just by the 3 gears separately in order to make up the kit???
Prices look a lot more affordable that the JK kit.. ;)
#8 [email protected]
[email protected]
    Minispares
  • Minispares
  • 3,208 posts
Posted 13 February 2008 - 11:56 AM
Correct. Bear in mind though, there are 2 types of idler gear, the timkin idler and standard straight cut type, and the prices are very different
#9 andydlc
andydlc
  • 77 posts
Posted 13 February 2008 - 12:09 PM
ouch! £80 difference..!
Oh well.. My saving grace is that I live in Jersey so prices are excl VAT.. woo hoo!!
#10 Ethel
  • 25,731 posts
Posted 13 February 2008 - 12:31 PM
I still think a Timkin equipped idler to fit standard transfers would be interesting. Any engineers out there got any thoughts on the practicalities of cutting a suitable hole in a gear?
#11 ginigwunkle
ginigwunkle
  • 2,018 posts
  • Local Club: sheffield mini club
Posted 13 February 2008 - 11:25 PM
dont med now do the transfers with rollers?
about 300 the set!
#12 1963MKI
1963MKI
  • 163 posts
Posted 10 July 2020 - 10:27 PM
just resurecting this topic, Ive got 1.08 straight cut jack knight drops for my mini with the tapered roller bearing idler. Does anyone know how to set them up, end float, etc etc ?or is it just knock them into the case and off with you !
#13 Spider
  • 14,495 posts
Posted 10 July 2020 - 11:05 PM
I did have a set of JKD Drops in my Race Car many many moons ago. I think I obtained them as a used set, but I don't recall doing much more than giving them the 'once over' and fitting them. I think from memory, they used a TR Bearing set but I can't recall how they were set for preloading, I * think * it was by the design of the shaft / axle that had a built in spacer ?
Not Timken, I'm sorry, 40 lashings for that, but a little like this ?
#14 Ethel
  • 25,731 posts
Posted 11 July 2020 - 07:34 AM
That'd be the very thing  :thumbsup:
Is it the same from the other side? I'm guessing there's a shoulder left in the middle? Difficult to machine?
