So to fully dry deck with oil transfer holes blanked too, (I will be using a remote filter housing because of access issues) will I need to blank off where the filter housing fits to the block with a plate and union so I can run to the cooler, then on to the hole in the block at the flywheel end of the engine. Then do I need to take a link off at that point to attach to the head? Where do you attach the head link? Assuming I have that right in the first place
ok oil filter re-position. some pics from mine. note Mine is a bit more than a reposition but it should give some ideas. re your set up i would run filter before cooler.
water drain plug removed
manifold in place
oil path across the front
old and new hoses
new position
