i've just stripped down my 2 engines that i used last year - both went bang and i couldnt work out why, both were fully balanced, timed up properly, rolling roaded etc
i had one L/C 1275 +40 AE 21251 and one H/C 1275 +40 AE 21253 built and i used AE pistons in both (as we are restircted by the rules) BOTH engines have had a piston break up in the same place
so has anybody else had this problem? or heard of anyone with this problem? or is it just my bad luck with BOTH engines
if other people have had a problem with these what are the alternatives ? bearing in mind these are my rules "No machining of pistons except for balancing purposes and this can only be carried out on the inside surface of pistons, and they must not protrude above block face, but some manufacturers have pistons that protrude as standard, so particular vehicles will be checked on their merit, according to manufacturers tolerances, for that specific vehicle. One piston and one con rod must remain as standard. Competition pistons are not permitted. Casting and/or forging marks to remain."
thanks
tom
Edited by Wessie28, 09 February 2008 - 12:01 PM.
